Question about Jabra GN9125 Wireless Headset
Pair jabra g9125 headset with base - Jabra GN9125 Wireless Headset
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Posted on Aug 23, 2008
  • 4 Answers
SOURCE: Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Posted on Aug 31, 2008
Spiker-123
  • 9 Answers
SOURCE: Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Posted on Apr 22, 2009
jazzbassist
  • 4 Answers
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Posted on Dec 16, 2009
Testimonial: "This worked perfectly! Thanks!"
kozachek
  • 122 Answers
SOURCE: i just bought a SANYO SCP-3810 phone thru sprint
The passkey for this headset is 0000
Posted on Mar 30, 2010
Jabra gn9350 base lights are not coming on.
There are a number of steps you can try to fix this issue:
1. Confirm the power supply is plugged in correctly, and the power socket to which it is connected is turned on and receiving power.
2. Remove the battery from the GN9350 headset and ensure the copper contacts on the battery and the headset itself are clean - a quick blow on both parts will be OK. You remove the battery by taking off the earhook or headband, and sliding the speaker section down towards the microphone boom - it will unclick. Reconnect the battery after you've blown on the contacts and re-pair the device as per step 3.
3. Re-pair the headset to the base: ensure the headset is docked in the base. Locate the button with two grey arrows pointing towards each other which is located on the side of the circular base section. Hold this button down for approximately 5 seconds, until you see a blue light flash on the headset itself - you can release the button once the light flashes. The headset is now paired again.
4. If the lights are still not showing up you may have a faulty battery, or a faulty headset/base.
Aug 30, 2012 | Jabra GN9350e Wireless Headset
Tip
How do I pair a Bluetooth headset Jabra?
<p>Jabra is the name of a company that was acquired by GN Corporation in 2000. The acquisition of GN strengthened position as a global supplier of equipment for hands-free communication environment. The name Jabra products to raise awareness and respect for the merger of corporations. In 2005, CN created the first Jabra headset that would work with Bluetooth technology for hands-free communication. Jabra is currently considered the first and leading provider of hands-free communication. Learn to use a Bluetooth headset Jabra Bluetooth is based on having in his pocket computer. <br /> <p><br /> <p>1. Turn your Bluetooth device to your computer. <br /> <p><br /> <p>2. Click Start and select Control Panel. <br /> <p><br /> <p>3. Double-click the Bluetooth icon and go to "Setup" option. It opens a wizard. <br /> <p><br /> <p>4. Step through the wizard. He should see your Jabra Bluetooth headset in place a discovery / sending mode. You hold the button on the Jabra headset it flashes green. <br /> <p><br /> <p>5. Click "Next" when it's time to find a nearby Bluetooth device. This, then, find your Jabra headset, because it was created in the previous step. <br /> <p><br /> <p>6. Click "Next" once the devices are paired and the headset at any time. <br />
on Jun 26, 2011 | Computers & Internet
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
Apr 15, 2009 | Jabra BT125 Headset
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Pairing
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Manual for Jabra BT 150
Go to page 4 Pair it with your phone
Did you know that if you have a bluetooth card in your computer you can also use this headset to listen to music. Do it everyday. It's great!
Mar 22, 2008 | Jabra BT150 Wireless Headset
Jabra GN9125 Wireless Headset Logo
64 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
