Question about Gcv160 Gas Engine
Could not get it start, no spark on spark plug
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Bad coil
Posted on Sep 09, 2014
My engine is vibrating and loss power
run the fault codes and find the reasons
Sep 07, 2015 | Cars & Trucks
Wont start no spark on spark plug
For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
May 24, 2012 | 1990 BMW 525i
CAN'T START CAR AFTER SMALL REPAIRS NO SPARK
Car has no spark?
This will help.
Thanks.
May 15, 2012 | 1992 Acura Legend
1990 Cadillac Seville won't start. Is it the electronic control module?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This For spark plug problem, click the help links provided below: ---
Car has no spark?
This will help.
Thanks.
Feb 19, 2012 | 1990 Cadillac SeVille
2001 Kia Rio, motor start very well first time after drive around 2 miles motor no start no more
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 03, 2012 | 2001 Kia Rio
Car will not start, engine turn fast enough to start. swapped relays still would not start. 2003 madza tribute.
Check if you have a spark by pulling the spark plugs and crank the car while the spark plug is on the ignition coil/spark plug wire and ground the threaded part of the spark plug and ask someone to start the car and look for a spark is a spark is present then ignition is fine. If spark plugs are wet and smell like fuel there is problem in the ignition system.
Mar 14, 2011 | 2003 Mazda Tribute
Will not start
THE BLOWERVAC COULD HAVE GAS PROBLEM OR A NO SPARK TO SPARK PLUG PROBLEM. TO DETERMINE THE SPARK PROBLEM FIRST, REMOVE THE SPARK PLUG, LOOK AT THE END OF THE SPARK PLUG (ENGINE END) TO SEE IF IT IS DRY OR WET WITH GAS, THEN RE-ATTACH THE SPARK WIRE WHILE THE SPARK PLUG IS LAYING LOOSE AND PULL THE ROPE TO TURN THE ENGINE AND LOOK TO SEE IF THERE IS SPARK OCCURING AT THE SPARK PLUG. IF THERE IS SPARK PRESENT, YOU HAVE NO PROBLEM WITH SPARK. REPLACE THE PLUG AND WIRE. IF NO SPARK CHECK YOUR WIRE LEADING TO THE SPARK PLUG TO MAKE SURE IT HAS AN ELECTRICAL CONNECTION AT BOTH ENDS, SPARK PLUG END AND ENGINE END. IF LOOSE FIX THE CONNECTION THEN RE-TRY THE SPARK/ENGINE TURN OVER BY ROPE METHOD AGAIN TO SEE THEN IF YOU HAVE SPARK. IF THEN YOU DO HAVE SPARK, RE-ATTACH SPARK PLUG TO THE ENGINE AND RE-ATTACH SPARK PLUG WIRE TO THE SPARK PLUG AND TRY THEN TO START THE ENGINE.
IF THERE WAS A WET PLUG WHEN YOU FIRST REMOVED THE SPARK PLUG AND YOU NOW HAVE SPARK AT THE SPARK PLUG, YOUR ENGINE SHOULD START.
IF IT STILL WILL NOT START AFTER THE SPARK CHECK, I WOULD REPLACE THE SPARK PLUG WITH A NEW ONE.
IF THEN IT WILL NOT START, THEN REMOVE THE SPARK PLUG AGAIN AND POUR A SMALL AMOUNT OF GAS INTO THE ENGINE SPARK PLUG HOLE. A PINT PLASTIC OIL CAP FULL OF GAS IS ENOUGH, DO NOT OVER USE MORE THEN THAT.
THE RE-ATTACH YOUR SPARK PLUG AND SPARK PLUG WIRE AND TRY STARTING THE ENGINE AGAIN. IT MAY TAKE SEVERAL PULLS TO GET THE EXTRA GAS IN THE SPARK HOLE TO BE USED UP BEFORE YOU START TO HEAR IT RUN ALITTLE AND FIRE NOW AND THEN.
IT SHOULD START THEN.
IF THEN IT DOES NOT START, YU HAVE USED UP THE GAS YOU PUT INTO THE ENGINE BY THE CAP FULL METHOD AND IT IS NOT GETTING GAS BY THE GAS TANK SUPPLY.
THIS MEANS THEN YOU HAVE AN IN LINE GAS LINE FILTER THAT IS PLUGGED UP OR YOUR GAS MAY BE OLD IN THE GAS TANK. IF GAS IS NOT OLD AND FILTER IS NOT PLUGGED, THEN YOU NEED TO REMOVE THE GAS LINE LEADING TO THE ENGINE CARBURATOR TO SEE IF IT WILL FLOW FROM THE GAS TANK OUT THE GAS LINE SUPPLY HOSE. IF IT DOES FLOW FREELY, THEN YOU DO NOT HAVE A GAS SUPPLY PROBLEM,
AS LONG AS YOUR GAS IS NOT OLD GAS. OLD GAS WILL GO BAD IN TIME. I'D REPLACE THE GAS WITH NEW AND TRY AGAIN.
IF THIS DOES NOT WORK, THEN ITS CARBURATION CLEAN UP TIME.
IT WILL NEED TO BE REMOVED FROM THE ENGINE BY A FEW BOLTS, HOSE'S REMOVED AND TAKEN APART AND CLEANED. TARNISH FROM GAS AND OIL WILL BLOCK THE CARBURATOR JETS AND VACCUM PUMP FROM WORKING PROPERLY. CLEAN AND REPLACE, TRY AGAIN TO START ENGINE.
MORE GAS IN SPARK PLUG HOLE TO GET GOING MAY BE ANOTHER ATEMPT AFTER CARBURATOR CLEAN UP.
Feb 20, 2011 | Homelite Mighty Lite Blowervac
Gcv160 Gas Engine Logo
46 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
