Question about Video Cameras
Foto jupe bugil - Video Cameras
P0440 CODE ON 2001 HYUNDAI
Evap System issue
Jupe that inst use google for all codes problems fixes & such
You Tube Video also
OBD PO440 type that in add your veh if you need more info
Aug 12, 2013 | Cars & Trucks
Nikon coolpix L100 screen just went blank and wont go on again
sounds like a bad sensor...... unfortunately this is a major issue... you are going to most likely have to send it to nikon to fix and it is usually most the cost of a new camera
Dec 02, 2012 | Cameras
Reset computer 2012 honda accord
there is no way to retrieve them, just have to drive until they reappear
Jun 09, 2012 | 2000 Honda Accord
Como imprimir una foto
Ver la foto, mantenga el dedo hacia abajo hasta la opción de guardar que aparece.Guardar la foto. Salga de la aplicación, e ir a sus fotos. Buscar la foto que acaba dedescargar y enviar por correo electrónico a ti mismo. Ir a la computadora de tu casa (ocualquier computadora con una impresora), abra su correo electrónico, e imprimir la foto.
Feb 28, 2011 | Facebook Apps
Dark screen
have you prove to pic fotos. if the camera make fotos,and memorize on the card, but you cant see the foto in the camera schreen this is only a lcd defekt, you must prove if the lcd flat is right connected. if the camera dont pics foto, the problem is in the ccd. you must change the ccd. allor. memorize fotos and you can see trhe foto on your pc...lcd problem contact failure ore lcd faul to change. if the camera dont pics foto...ccd failure to change the ccd.
May 30, 2010 | Canon PowerShot A95 Digital Camera
Blurred fotos
Turn off the Macro shots feature. and your shots will be fine.
Oct 31, 2009 | Olympus SP-700 Digital Camera
Enviar fotos por sms
Necesito enviar fotos por mensaje
Sep 01, 2008 | Cell Phones
APRENDER A MANEJAR PHOTOSHOP SOLO PARA GUARDAR FOTOS
Bajar fotos? Te refieres a abrirlas en Photoshop y luego guardarlas formato photoshop?
Si esto buscas, solo tienes que abrir el programa y seleccionar open, luego buscas la foto y le das a open.
O
Buscas la foto y le das un 'right-click' y le das a abrir con -- seleccionas photoshop.
Una vez tengas la foto en la aplicacon, para guardarla vas a l mismo menu y le das a guardar. Se te guardara formato photoshop.
Si quieres guardarla con otro formato entonces le das a save as y seleccionas el formato que quieras.
Apr 29, 2008 | Adobe Photoshop 7.0 for PC
Video Cameras Logo
202 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
