Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I have an ESP 6100 & can't copy
I installed a color cartridge 10c b/c it wouldn't let me make copies. Now it won't turn off & in the window it just says, starting up. How do I fix this
SOURCE: kodak 5100 no black printing, light on colors
Had the same issue... No black ink. Called the # from "Solution #1" guest, 18004216699. Had to patiently go through all the basic trouble shooting stuff like calibration, print head clean, demo print, etc. Once I went through that, they issued me a new print head for free, no shipping charges or anything. Just did this today, but they say I should have the print head in 3 days.
For once, service worked like it should!
Posted on Jul 19, 2008
  • 96 Answers
SOURCE: printer does not make black
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 26, 2008
  • 214 Answers
SOURCE: Constantly cleaning the print head
I feel you should take it back. Under warrantee?
Posted on May 01, 2009
  • 295 Answers
SOURCE: esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Posted on Jul 27, 2009
  • 103 Answers
SOURCE: Kodak ESP 5 new cartridges color prints fine black
Try cleaning the printhead.
Press Menu > Select maintenance > Select clean printhead.
If still black does not print, call Kodak tech support, printhead will be replaced free of charge
Posted on Jan 23, 2010
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I was recently given a 5300 all-in-one printer.I want to replace the ink cartridges. I bought ink(kodak) and want to make sure it is correct before I open the box. I bought an ink combo pack for an...
You got it right - the Kodak EasyShare 5300 All-in-One uses 10 series Kodak cartridges, and
since your box says 10B+10C, it has (2) 10-series cartridges in it - one 10-series Black (10B), and
one 10-series Color cartridge (the 10C).
The 10 Series Ink cartridges are compatible with:
EasyShare 5000 series (your All-in-One belongs here)
ESP 3/5/7/9
ESP 3200/5200/7200/9200 Series
ESP Office 4100/6100
Reference:
http://store.kodak.com/store/ekconsus/en_US/list/Ink_Cartridges/10_Series/categoryID.53666600
Mar 18, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just installed my new esp-3 printer will not print or copy any colour just washed out black/white
Check if you have removed cartridge protection tab from color cartridge. see MANUAL for assistance. If removed try to find you printer must have COLOR to B/W switch. Check if color light is on. If it printed test page and it wasn't color you may not installed cartridge correctly.
Aug 01, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
May 01, 2009 | Kodak ESP 5 Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
16 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
