Question about Maytag Dependable Care LAT9416
How to open up a maytag dependable care washer to work on it.
5 Suggested Answers
SOURCE: Maytag Washer won't switch from rinse to spin
You have a bad lid switch. Before I retired Maytag had a lid switch kit that improved the switch that was originally in it. The problem would usually present itself if a person accidentally dropped the lid with a bang which would put the lid switch out of adjustment.
Posted on Feb 01, 2007
jsrock516
  • 5911 Answers
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Posted on Aug 09, 2008
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
SOURCE: where is the lid switch for reset on a maytag
where is the lid switch for reset on a maytag dependable care washer
Posted on Jan 30, 2010
Maytag dependable care plus washer. Top Loader works through all cycles, but will not initiate or complete final spin.
Bad lid switch wore out needs replace ment or you have bad pump and takes to long to drain send us a model #
appliancexchange@gmail.com
Jan 30, 2013 | Maytag Dependable Care LAT9706
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Where is the lid switch for reset on a maytag dependable care washer
Dec 19, 2009 | Maytag Dependable Care LAT9706
Should I buy a gently used Maytag dependable care plus model# LAT8824AAE washer? What's the reliability of this machine?
Maytag makes very dependable machines. They are fairly easy to repair and parts are easy to find. If I was in the market for a used washer, a Maytag would be my first choice. Since its used there is no guaranty that the thing isn't going to need repairs. If you can see it run through a cycle before buying it would be a plus. My first washer was a mid seventies model Maytag. I had two minor repairs twice in 15 years and its been working ever since at my buddy's. I hope this helps you.
Aug 27, 2009 | Maytag LAT3600A Top Load Washer
Washer quit mid cycle
open lid pull tub to you till you hear a click(when you have an off balance load the tub will trip the switch)
Aug 22, 2009 | Maytag Dependable Care LAT9706
Aug 08, 2009 | Maytag Dependable Care LAT9706
Maytag washer wont fill, spin, or do anything.
Open the control panel and check the micro switch beside the lid switch .
Mar 19, 2009 | Maytag Dependable Care LAT9206
Washer Maytag
To get access to internals you have to remove back panel of machine and then other 3 sides that then exposes the parts you need to get to eg. drainage hose,s
Apr 20, 2008 | Maytag Dependable Care LAT9706
Washing Machines Logo
379 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
