Question about 2005 Volvo V70 - Fits the S Diesel Models - Sporttech Springs
Handbrake cable adjustment
How do you adjust the handbrake cable
    Problem Solver:
  • 16 Answers
To adjust the v70 parking brake, gently pry up at both front and back edges of plastic retaining cover for parking brake handle boot. Pull up on boot and invert. Lift up on white plastic dust cover. Set parking brake at one click. Using 10mm box wrench, tighten or loosen adjustment screw until desired tension is reached. That should be done by the mechanic when your brakes are replaced.
Posted on Dec 28, 2014
How to adjust rear brake shoes on citi golf 1.4 i
the rear shoes are auto adjust so if the handbrake cable has not been over adjusted and is not siezed then it should work ok what i would do is to slacken off the handbrake cable. make sure the shoes are good and the auto adjusters are free then drive it for a run and keep using the foot brake then readjust the handbrake cable
Mar 21, 2018 | Cars & Trucks
Handbrake adjustment citroen nemo
Remove the boot around the hand brake or pull it back to expose the adjustment nut and locking nut on the threaded cable end, turn it clockwise to tighten the handbrake cables.
Aug 09, 2016 | Citroen Cars & Trucks
1.9vauxhall vectra C fitted new pads and hand brake cable now handbrake has too much travel same as before items were fitted
it looks like a common flaw in design
it can fail an mot if handbrake wont hold
with both wheel of the ground and hand brake fully applied do the wheels spin
handbrake cable system on a
1.9vauxhall vectra C says self adjusting
but this picture implys there is an adjustment point
source
Thread Handbrake adjust
you tube vectra handbrake system in action
Opel vectra handbreak
Jun 15, 2016 | Cars & Trucks
Adjusting hand brake
there is a cable adjuster under the center console if its got a rear ashtray just pull that out and look there.but you should remove the rear brake drums and check the shoes. and the handbrake fulcrum levers, they can sieze up. also make sure the levers return to the stops with handbrake off and the auto adjusters are working ok before adjusting the handbrake cable! it helps brake performance if you give the auto adjusters a bit of a tweak before putting the drums back on. manually adjust 3-4 clicks or until the drum goes back without binding.
May 29, 2013 | 2005 MG ZR
My handbrake needs adjusting in my Toyota Corolla 1994. Can u please explain how this adjustment is done.
Hello, My usual Brands are Ford products, but Foreign cars usually use simple, less expensive ways to do things. Assuming the brake pads are good, there should be a cable connected to the handbrake. You would usually pull the handbrake up to engage about 1/4 the way to engagement and lock it there.
Then you would go underneath the car and find the cable that stretches from the handbrake lever to a juction with a second cable. There should be an adjusting thread somewhere at this intersection.
With the rear wheels off the ground, you would tighten the nut on the threads of the handbrake cable until you hear rubbing in the rear brakes. Then get inside the car and pull back on the handbrake lever and you should not be able to move the rear wheels with the handbrake set. You then release the handbrake 100% and the rear wheels should turn mostly without noise.
Now if you can not find an adjustment nut under the car, it is possible the handbrake adjustment nut is under the handbrake cover/boot inside the car. Still use the same process of setting the lever 1/4 engaged and tightening the threaded cable until the rear wheels start dragging.
I hope this helps you.
Sep 28, 2011 | 1994 Toyota Corolla
Ford bantam handbrake adjustment
remove the back brake drums ,slacken handbrake cable then run a mini grinder around the lip on the edge of the drum .Then adjust the auto adjusters manully so when the drum is push on it just goes on ,tap with a hammer all around the drum to level the shoes and if need be adjust up a bit more ,then when finished re-adjust the cable so you have three notches on handbrake lever
May 31, 2010 | 2006 Ford Focus
How to adjust handbrake on a 2004 passat
a word of caution, before adjusting the parking brake make sure the rear adjustment is working and properly set up
Nov 26, 2009 | 2004 Volkswagen Passat
How do you adjust the handbrake on a 1996 Peugeot 306 XR Hatchback ?
Handbrake is normally mechanically connected to
the brakes by steel cable 1/8 inch thick. At the end of the cables are bolts with adjusting nuts to adjust the handbrakes. These nuts must be adjusted to have an equal tension on the brakes, otherwise, swerving may result. It is advised to have a mechanic todo this job.
Sep 21, 2009 | 1984 Peugeot 604
How to adjust handbrake cable
HANDBRAKE CABLE ADJUSTMENT
1. Raise the vehicle and release the handbrake.
2. De-adjust the handbrake cable.
  • Remove the locking pin.
  • Slacken the adjuster locknut.
  • Slacken the adjuster until the levers on the callipers have returned to their stops.
3. Paint alignment lines on the lever and caliper
4. Tighten the adjuster until the caliper levers move from the alignment lines.
5. Apply the handbrake to equalise the cable.
6. Tighten the adjuster locknut to a minimum of three clicks and a maximum of six clicks.
7. Fit a new adjuster locking pin.
8. Lower the vehicle.
Jun 04, 2009 | 2002 Toyota MR2 Spyder
Volvo s40
The handbrake adjuster is under the centre console behind the lever. If its coming too high, check that the levers at the rear brake calipers are free and moving back to their stop position - they are prone to seizing up on older or little used cars. They can usually be freed off with a bit of lube and working the lever back and forwards. If that dosn't work, unfortunately you'll need new calipers. Do not adjust the handbrake cable unless the caliper levers are at their stops as this seriously reduces handbrake efficiency!
Jan 08, 2009 | 2000 Volvo S40
2005 Volvo V70 - Fits the S Diesel Models - Sporttech Springs Logo
110 people viewed this question
Top ST Suspension Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a ST Suspension Vehicle Part and Accessory Expert? Answer questions, earn points and help others
