Question about Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation
Km 452 dwu
I picked up this machine recently, it is in very good shape and is very clean. However the compressor has been removed. I do not have experience with the water cooled types. I would like to know if it needs any thing else. Is there a diagram or picture showing the layout. I am especially curious where the water flows to and how to check if ther are any leaks into the freon system.
  • 462 Answers
See if it has any pressure in the sealed system. If so its probably ok.
Water cooled machines here in Oklahoma have to have a new water valve about ever 2 to 3 years or water will flow all the time. The plus is you can install it in a hot kitchen or garage and it will continue to make ice. The bad thing is it takes a lot of water.
If your inclined you could set up a cooling tower and spray the water out and collect it back in the sump and push it back in to the condenser with a pump. If your in Arizona this might be a cure for water use. Other wise get ready for a mess if you don't pipe it into the drain on the building. Keeps the misquotes happy though.
Posted on Mar 28, 2009
How do I clear A-4200 on a Kyocera copier KM 2016
May 21, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
The bike does not want to pick u refs
Do you mean "does not want to pick up revs?" Start with top quality fresh clean gasoline, be sure your lines and filters (one in the tank?) are clean. New spark plug, be sure your wires are all clean and in good shape; move to be sure your exhaust is not plugged. Did you do any recent mods? New air cleaner or pipes almost always require re jetting or remapping.. Reply with your results and more symptoms. Good luck!!
Jan 01, 2015 | Motorcycles
Hoshizaki ice machine model km 900mwh low side suction line has ice building up on it all the way to the compressor
Is it making ice? Frost on this line is not that uncommon as it is colder than the air around it. Make sure you have good water flow over the evap plates. machine may just need a good chemical cleaning.
Jun 14, 2014 | Hoshizaki Commercial Freezer KM-500MAH
My air compressor continuously pumps but does not exceed 20 psi
My compressor had a very similar problem. Once I disassembled the heads, I found that the valves were broken. Solution: rebuild top end. Make sure the seats are in good shape or replace with a new pre-assembled one. Check to see if cylinder walls are in good shape.Minor scoring is a acceptable. valves are not like auto valves and are assembled units. Pay close attention where seals go. Some compressors can remove the valves without removing the heads.
Jan 05, 2011 | Air Tools & Compressors
What size breaker and wire is required to operate the miller 452
You can tell by the plug configuration. The shape of the prongs. No Manual?
May 18, 2010 | Miller Electric Mfg Co 903394 Deltaweld...
The compressor has a max working pressure of 12 bar but at the moment is maxing out at 7.5 bar how do i adust it
The switch is probably located between the motor and the compressor ( a small square box), unplug the machine, remove the box cover. You should find a screw adjustment there, clockwise for higher pressure usually.
12 bar is 175 PSI, is your machine in good shape to handle it?
Most air tools only need 90 PSI.
Apr 25, 2009 | Air Tools & Compressors
KM-450MAB making beaping noise-compressor will not run
The cleaning valve must be closed duing the ice making mode. If it is open, the machine will not make ice. The beeping you hear is the alarm which is present on the machine. Remove the front cover and read the included text. This will tell you what alarm you have.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
181 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
