Question about Video Game Consoles & Games
R6002 - floating point not loaded - Video Game Consoles & Games
pcs365
  • 128 Answers
SOURCE: error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
Posted on Jun 04, 2010
eng_darwish1
  • 233 Answers
try using windows 2000 or windows xp sp2 compatablity mode for the executable file that causes the error
Posted on Jun 05, 2010
SOURCE: how to remove/fix the "Runtime
Try to uninstall from add/remove programs and then reinstall the program/application
Posted on Sep 16, 2010
steeldevil20
  • 52 Answers
SOURCE: When i open picasa it shows run time error R6002
This problem can either because your using a lower version of windows, your system might be infected or your registry might be corrupted.
You can try downloading a lower version of the picasa and try installing that on your system.
Another alternative is to fix your registry. In order to fix your registry download a software ccleaner from the following link:
http://www.piriform.com/
Download and install it. Open the software choose registry option and scan for issues. After the scan is finished you can click the fix selected issue option to fix the errors.
After fixing the registry you can try installing the newer version of picasa and see whether the problem is still there..
Posted on Nov 16, 2010
DMZ ZONE
  • 53 Answers
SOURCE: r6002 floating point support not
Hi
R6002 is a run time error which can occur in your system.This happens when there are some files missing or corrupted in the registry..Nothing to worry about though because this specific error hardly affects your usage as you will be able to use all the applications normally.But in some cases errors in the registry can also cause serious damage to your pc.So my suggestion will be to install a registry fixer or cleaner software and run it once a week or month depending on your usage.But beware not all registry cleaners are genuine and will ask you to pay for it. So the best program to fix your registry will be CCLEANER from PIRIFORM which is free.Following is the link to download ccleaner-:
http://www.filehippo.com/download_ccleaner/download/81bb508f8b3bb99cd1e6670e7cbfa38b/
Copy and paste this link to the address bar and download the setup file.After downloading install the software and run the software.As soon as it opens up you will see four options on the left hand side ie.CLEANER,REGISTRY,TOOLS AND OPTIONS
Select registry and click on SCAN FOR ISSUES.Now when the scan is complete click on FIX SELECTED.
Restart your computer and it will not give the same error again
Hope this fixes your problem if not please reply
Thanks & Regards
LonG LIVE tHe GeEKs!!!!!
Posted on Dec 09, 2010
RUNTIME ERROR,R6002-floating point support not loaded.Unable to download file.Make sure the computer has a working connection to the Internet before trying again. Even i have already connected online.
I would suggest you to consult an experienced technician to resolve your issue.
I had the same issue last month. I got a good assistance fromthebestpcdoctor.com. They got ta toll free number (877- 407-9229 ), I called em ..up and my issue is solved..
Sep 24, 2011 | Microsoft Windows XP Professional
When i open picasa i get an error like Runtime Error! program:c\program files\google\picasa3\picasa.exe R6002 floting point support not loaded please help me about it
Here is the problem and the (weak) solution:
You install picasa 3 and run it. It works.
Than you close it and start again (or restart computer) and you receive the error:
I've uninstalled picasa 3, cleaned my registry with CCleaner, downloaded the picasa 2 and it worked.
Maybe it will work without cleaning the registry.
I use windows XP SP2. To fix the problem I've also tried upgrading to SP3, but it didn't work.
I think it has something to do with hardware, because I have installed the same copy of windows on 2 computers and picasa 3 works on one of them.
Jul 21, 2011 | Computers & Internet
I m start logitech vid upgrade but error in upgrade run time error ROOO6 floating point support not loaded.
only solution i could find on the web http://www.articlesbase.com/data-recovery-articles/runtime-error-r6002-floating-point-support-not-loaded-quick-solution--974414.html. i would suggest running ccleaner from filehippo.com and run the cleaner first that should prob do the trick. let me know.
Mar 15, 2011 | Cameras
R6002 floating point support not loaded
Hi
Thanks & Regards
Dec 09, 2010 | Computers & Internet
When i open picasa it shows run time error R6002 floating point support not loaded in picasa. what should be done?
Nov 16, 2010 | Global Star Software Picasa for PC
Error R6002 floating point not loaded
Jun 04, 2010 | Microsoft Windows XP Professional SP2
Jun 04, 2010 | Sony VAIO® VGCLS1 PC Desktop
Floating point support not loaded
it could be a virus
try to download combofix and run it
Jul 09, 2009 | Computers & Internet
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
