Question about HP DeskJet Office Equipment & Supplies
Cannot print documents keep getting error state
SOURCE: the "keep printed documents" stays checked after i uncheck it!
Had the same thing happen. Go to properties, then advanced and check "print directly to printer". You'll be able to print your coupons. Make sure you go back to your previous settings when not printing coupons.
Posted on May 28, 2008
SOURCE: I keep getting print errors.
hi,
I have ever get same problem with same printer model.
I have change the usb cable.
May be this can help
Posted on Dec 14, 2009
  • 1218 Answers
SOURCE: When trying to print a
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Nov 15, 2010
archaeology
  • 662 Answers
SOURCE: My HP Officejet 4500 won't
Hewlett-Packard specifically documents how to deal with this error here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02450835&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=3919448#N74
Posted on Mar 15, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: printer keeps saying busy printing another document
    A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
    If that doesn't help, try the steps below:
    1. Disconnect the USB cable connecting the printer from your computer.
    2. On your computer, go to Control Panel > Printers and Faxes.
    3. Delete the Lexmark print object.
    4. Reboot computer.
    5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
    6. When the printer turns on, reconnect it to the computer.
    7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
    Posted on Feb 14, 2012
    I keep getting internal error when I try to access Adobe Reader and I'm trying to print a State application run on Adobe and it won't print the inner application please help!
    Adobe shoud not malfunction. if it does, a newer version ungrade resolves the situation. computers connected to the internet simple acquires adobe updates recent features to perform desireably. Once installed, any document should be readable, printerable, saveable or manupulated on the computer.
    Jan 29, 2011 | Office Equipment & Supplies
    Error message stating 8documents waiting to be printed. I cancelled them but the printer will not print new documents. there were previous documents printed and I did not want to finnish those documents so...
    Sounds like a driver problem. I would try disconnecting the printer from your computer and power cycling it (unplug it for a few minutes). While it's unplug uninstall and then reinstall the print driver. If that does work email me.
    panderson@cartridgeworldusa.com
    Jan 14, 2010 | HP Officejet 5610 All-In-One InkJet...
    Canon IP3000 fault
    Here are a couple of documents related to your problem (appears to be a print head error);
    Error code synopsis;
    www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
    Full product manual;
    www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
    Doesnt look terminal, at worst may need to replace the Print Head.
    Hope this helps.
    Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
    Printer will not print, as it will not cancel the last document waiting to be printed. Then it says printing started and copies the document to 50 50% and then completely stops.
    Not really a solution but...My error states "Unable to Print 50" with a yellow exclamation point. This happened after a paper jam. Still trying to get the answer and will let you know when I do.
    Nov 25, 2008 | Lexmark Office Equipment & Supplies
    The "keep printed documents" stays checked after i uncheck it!
    May 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
    HP Deskjet 3820 states system error
    try disconnecting from computer, and run the test page from the panel..then, reconnect to computer and see if it repeats..sounds like the operating system may have lost the printer drivers..
    Mar 07, 2008 | HP DeskJet 3820 InkJet Printer
    14 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
