SOURCE: Need forward & reverse plastic key buttons
Spray some contact cleaner into the buttons and this may free them up. try this
SOURCE: Wilson Jones Shredder Automatic On/Off
When auto function does not work there are two things to do 1st. canned air is your friend try blowing out the photo sensor that makes the auto function start. It is located in the very center of the feed point upper and lower parts meaning two areas to clean. they usually are little round spots when paper dust gets on them they either continuously run or do not run. Now 2nd if cleaning does not help then you may have bad photo sensor. you will need hands on tech. respond if having trouble and leave feedback if this helps. Have a nice day!
SOURCE: shredder says service due. cannot clear display
Clearing the "Service Due" prompt:
1. Lift safety flap (plastic cover over paper entrance).
2. Depress Reverse and Stop button simultaneously 2-4 seconds.
3. LCD display reads, "Service Info 1"
4. Press Stop button once to obtain "Service Info 2"
5. Depress Forward and Reverse buttons simult. 2-4 seconds.
6. "Service Due" prompt will be cleared and service hours zero.
7. Snap safety flap down to close.
SOURCE: wilson jones shredder model 1350 problem
Hi sambmachine,
If you're looking for instructions on how to clear the code of your Wilson Jones Shredder, please follow the steps below. Hope it may help you on clearing the service due code.
Step 1. Lift the safety flap. It is the plastic cover over the paper entrance.
Step 2. Now you need to depress Reverse and stop the button simultaneously for about 3-5 seconds.
Step 3. The LCD display will reads, [Service Info 1].
Step 4. Please press the [stop] button once to have the [Service Info 2].
Step 5. Now Depress Forward and Reverse buttons simultaneously for about 3-5 seconds.
Step 6. You gonna have [Service due] prompt, it will be cleared and service hours will go back to zero.
Step 7. You can now snap the safety flap down to close.
Hope it helps.
Thank you for using FixYa.
SOURCE: Shredder is Wilson Jones 130
Oddly, my Wilson Jones 130 auto just did exactly the same thing. I'm the only one that uses it (that I know of) and one day it worked, the next it didn't. There is no paper stuck in it. There are no power lights, nothing works. Does anyone know the location of a reset button or something?
