Question about Toys
Swing problem grinding sound in slewing ring
2 Suggested Answers
simontricket
  • 235 Answers
SOURCE: slew ring
You got one ring of bolts holding the trackframes to the ring and one ring of bolts holding the cab frame to the ring .Undo all the bolts and the 3 parts will be separate - problem here is what weight is the machine .
Posted on Dec 31, 2009
Hi i have a bobcat 355 g 2005 model it makes a clunking sound when slewing and the slew brake fails to work some times any hints guys
indicates that the sprocket teeth are damaged/ worn and it is mismatching
could be from failing slew bearings
check brake adjustment and pad lining thickness
best get a bobcat service center to check it out
Jun 20, 2017 | The Optics
I went to train the drive on a Meade EXT 125 the slew moved extreamly slow to the right and would not allow to center to the left on the next step. Now I can't slew to the right it sounds like the gears...
I have a YouTube video about this just search for Telescopeman on YouTube. However if you cannot move the scope up-down-left or right with the controls either the hand controller is defective or something is broken inside the scope. Possibly a worm gear is not engaging or is simply broken.
https://www.youtube.com/watch?v=iv9BCpcF5mc
Feb 14, 2015 | Meade ETX-125AT (500 x 138mm) Telescope
Abs light on/grinding and clunking in turns on front left side of 2003 ford explorer
Sounds like left front loose wheel bearing knocking ABS sensor out of range causing ABS light to come on and causing grind noise at same location. Grinding noise is probably rotor rubbing on calipar.
Aug 27, 2014 | 2003 Ford Explorer
2008 flhrc starter grinding sounds
Usually, starter grind is either incorrect pinion gear and clutch ring engagement, or a damaged overrunning clutch drive assembly.
Sep 11, 2012 | 2008 Harley Davidson FLHRC Road King...
2001 chevy silverado 4x4 still grinds after pulling rear drive shaft
i have seen strange grinding sounds come from a broken span ring inside the transfer case the snap ring is more common to break when loading trailers in park
Jul 13, 2012 | Chevrolet 1500 Cars & Trucks
Fisher Price power plus swing
I just went onto Ebay and searched for your tray. A slew of FP trays came up. Good luck!
Jan 06, 2012 | Toys
Slew ring
Mar 25, 2009 | Garden
Solis Maestro Plus: Grinding Adjustment does not move and can not take out Grinding Ring
Hi
Sounds like you may have broken off the adjustment tabs on the outer ring. Contact Baratza for help.
Jul 12, 2008 | Solis Maestro G385 Electric Burr Grinder
Trouble shooting
my Meade ETX-125 makes a grinding noise when I try to slew to the left and will not move. Any suggestions will be appreciated. Bill
Aug 30, 2007 | Meade ETX-125EC (500 x 127mm) Telescope
Toys Logo
14 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
