My fd-10 pin pad has an error dkey is empty what can i do about it
Oven no heat
What is the model number?
Oct 25, 2013 | KitchenAid Kitchen Ranges
Gettin no Dkey error
your pinpad probably not loaded with the right encryption. call your processor. thanks
Sep 12, 2011 | VeriFone PINPad 1000SE Network Terminal
Remving caliper pins on 2000 vw jetta and caliper
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
For front brake pads. You should buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose!
2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper.
3. Now you must thoroughly clean the brake calipers (free of grease).
4. Remove outer brake pad from brake carrier.
5. Pull inner brake pad out of brake caliper piston.
6. Check up the brake fluid level on the reservor, and emptying if neccessary!
7. Push piston back into brake caliper housing.
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward).
9. Install outer brake pad into brake carrier.
10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm.
11. Install both caps.
12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
Jun 26, 2011 | 2000 Volkswagen Jetta TDI
I want to change my front brake pads How do I remove the old ones
Apr 12, 2011 | Volkswagen Polo Cars & Trucks
Anything special about changing front pads on audi a3? I've done honda, acura and toyota's.
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Check up the brake fluid level on the reservor, and emptying if neccessary! 7. Push piston back into brake caliper housing. 8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 9. Install outer brake pad into brake carrier. 10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 11. Install both caps. 12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
Aug 25, 2010 | 2007 Audi A3
WHAT TOOLS ARE NEEDE TO REPLACE AUDI A3 SPORTSBACK FRONT BRAKE PADS
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. You must buy the brake pads with wear sensor. For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exists, must point in direction of brake disc rotation when vehicle is moving forward).
Feb 14, 2010 | 2006 Audi A3
Nurit 2085
Is the pin pad plugged into the port marked pin or the port looks like a small pin pad? Th most important thing is do not unplug the pin pad while the terminal is on you risk the chance of loosing the encryption the pin pad has programmed into it. If this happens you will need your processing company to re encrypt the pin pad. Turn the terminal of make sure all connections are nice and tight power back on. If no luck call your processing company.
Mar 04, 2009 | VeriFone (M19755014US1) Magnetic Card...
Pinpad won't work, but has worked before.
The encryption that is loaded on the pin pad is wiped out; this may have happened when powering off the terminal, unplugging the pin pad without unplugging the terminal power source first. What you would have to find out is what platform you are on from your processor, if they are not willing to do it, you can contact companies that will reprogram your pin pad. This will be cheaper than to buy another pin pad.
Dec 12, 2008 | VeriFone PINPad 1000SE Network Terminal
Loose bracket or plate...
IF YOU ARE TRYING TO RE INSERT THOSE PINS YOU GOIN TO HAVE A HARD TIME.THOSE ARE CALLED TRANSPORT BRACKETS AND NORMALLY COME WHEN THE MACHINE IS NEW ITS NOT IMPRTANT TO RE APPLY THEM IF YOU INTEND MOVING THE APPLIANCES.GOOD LUCK.MOHAMED
Aug 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Microsoft Retail managment system
You need to have the correct keys loaded into the pinpad. If you got the pinpad from some place other than from your processor, you are out of luck. They will only load the keys when the pinpad is physically in their possession.
Feb 29, 2008 | VeriFone PINPad 1000SE Network Terminal
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
