Question about Radio Communications
I have a n2vz turbo tuner interface with a ic706mk2 and tarheels 100a hp antenna when tuning get s.s.s.
When i push the tune button to tune i get mose code of s
3 Suggested Answers
SOURCE: Saturn workman b-100
I just bought this antenna and i saw that swr was off the scale so i was thinking and thought of trying a ground on the bracket of the antenna and when i did that the swr's were totally flat. When i did that i called my buddy and told him to let me know what the signal was with this antenna and he said it was like 91/2 pounds for signal and that was with it in my bedroom. so i would just put a ground wire on the bracket andyou would be good.
Posted on Jan 18, 2009
  • 219 Answers
SOURCE: Hooked it all up per the manual, Clean power,
Have you tried it in another truck where a radio does work? If so and it didn't there either I'd say you have a bad radio.
Posted on May 04, 2010
N2vz tuner doesnot tune antenna doesnot move all settings per instructions
Try www.mods.dk. They have tons of free manual downlods and mods for HAM radio and other equipment that hams use. It's the BEST online source for this type of information.
Apr 27, 2014 | Radio Communications
Kenwood ts-2000 internal antenna tuner fail to tune
it's not failing to tune, it shutting off as tuned. 1.25:1 is below it's threshold to tune
Feb 05, 2014 | Kenwood TS-2000
Technics ST-S3
1. Select the lowest FM frequency you want manually. You should hear it.
2. Press MEMORY followed by preset one.
3. Repeat the process for the remaining frequencies and buttons.
If you don't hear anything when you tune manually, the frequencies are not being received with enough strength. There could be an antenna problem.
Dec 28, 2013 | Audio Players & Recorders
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
Furuno at 1500 atu
This works for the Furuno 1501-Make sure your connections are the same:#1 provide 15V & gnd to tuner(12V works) #2 connect coax between tuner & Xmtr / antenna to tuner #3 set radio to transmit CW carrier @ no more than 10W #4 momentarily short tune to gnd, this will initiate tune process. Watch SWR meter/ listen for tuner to complete, stop 10W carrier & return radio to normal status. I use mine remotely mounted with a 3 wire control cord & a box with a push button momentary switch back at the radio. Connections are 12V & gnd from the power supply to tuner, tune back to control box where the button shorts it to ground to tune.
Apr 23, 2012 | Furuno FS1503 (199 Channels) 2-Way Radio
I have recently bought a sharp aquos lc 40 le811e tv set,im havin problems tuning it i have a new antenna installed and when i try and auto tune it says there is no signal,i have also tried 2 differant...
Does it have a built in digital tuner? unplug wait 5 minutes hold power button while you plug it in you should get into a secret menu usd by techs look and see if you have a digital tuner hope that way works for that set
Jan 27, 2011 | Sharp Televison & Video
How to program channel without remote
First be aware that if you are using an antenna this television has an analog tuner which is no longer capable of receiving any digital signals which is the only channels being broadcast as of June 2009. If you have a cable or satellite receiver then here is the procedure for auto programing your channels. Make sure your active cable/satellite is plugged into Ant 1 (Antenna 1) on the back of your set.
On the front panel push the menu button until the "Channel" is highlighted. Then push either the plus button or the down button to highlight auto program.
Once that is done push plus or up and the set will automatically tune in all the available stations
Zashiban
Jun 04, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Jan 05, 2010 | Music
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Radio Communications Logo
114 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
