Question about Champion Juicers
Champion pressure washer spares - Champion Juicers
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
Champion juicer can't get metal plate off bottom, screws tight
Ants OMG! what a nuisance. I suggest calling The Wholistic Research company who sell champions as they may be able to help
Dec 15, 2013 | Champion Juicers
I need a screen and instruction for the juicer. where can I get them?
You have probably already sourced these items but www.wholisticresearch.co.uk are very good and sell spare parts for these machines.
Sep 13, 2013 | Champion G5NG853S 540 Watts Juicer
We just got a 2nd hand juicer CHAMPION model G5-NG-853S. Where can I find a manual for it.
The CHAMPION juicer manual is online at: http://www.discountjuicers.org/manuals/champion.pdf
If your juicer needs parts or maintenance, the phone support is easy to work with - call them directly at:
(209) 369-2154
Jul 26, 2011 | Champion G5NG853S Household Juice...
Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
May 02, 2010 | Champion 2000+ Household Juice Extractor
Champion juicer developed a high pitched squeal
Champion Juicer manufacturer has an oil refill for 5 or 6 dollars. I just ordered one and I expect that should solve the problem.
Apr 29, 2009 | Champion G5NG853S Household Juice...
Cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Jan 30, 2009 | Champion Juicers
Pulp gets stuck in Champion
Feed it slower. Mix up the items, it likes things mixed up. You can add water near the end to clean it out.
Jan 20, 2008 | Champion 2000+ Household Juice Extractor
Cutter
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
Juicers Logo
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
