Question about Refrigerators
Kitchenaide model KSF26C4XYY refrigerator has Refrigeration Cooling Is Off display is on and will not reset
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
SOURCE: Refrigerant problem
could be that the freezer is iced up and causes it not to cool properly, maybe try defrosting it
Posted on Oct 04, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Posted on Oct 24, 2009
  • 137 Answers
SOURCE: I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Posted on Nov 28, 2009
heatman101
  • 43501 Answers
SOURCE: not cooling refrigerator part
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgjkgd
Posted on Sep 29, 2010
KItchenAid side by side freezer is not cold enough. Pressed the optimice button and it gets the temp where it is fine. Then, it gets warm again. Already checked coils everything fine
if everything is fine, then what is the question ?
if it isn't cooling, get a trained refrigeration technician to look into fixing it. refrigeration equipment takes specialized equipment and training well beyond the average homeowner tools or skillset.
Mar 25, 2018 | KitchenAid Refrigerators
Changed water filter red light still on
Check for a reset, or unplug just for a min or two. Then check.
Sep 11, 2015 | KitchenAid KSF26C4Xyy Side by Side...
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Inside led lights of KitchenAid KSF26C4XYY not illuminate
There is a switch (somewhere on the door frame) that has to close to turn the lights on when a door is opened . They are pretty reliable, but if a switch fails due to a mechanical problem, you can sometimes tell by the feel when you operate it manually. If your switch seems OK, then I'd wonder about the power supply for the lights (which I know nothing about).
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Funny noise coming from the air filter
probably bad ice maker
http://www.shopjimmy.com/
Sep 06, 2012 | KitchenAid Refrigerators
What type of freon is used to charge system.
It should be R-134a, but you should check the rating plate for refrigerant type and for the proper weight of the charge...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Mar 10, 2011 | KitchenAid Superba Architect KSCS25INSS...
Samsung model rs267 says OF on both temp displays
Freezer and refrigeration isn't working
There is no temperature indicating for Celsius of Fahrenheit it just displays OF.
The letters "OF" on the display of your refrigerator indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and the display returns to normal, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air. Thanks-Helpful?
Feb 07, 2011 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
