Question about Husqvarna 20" 60cc Rancher Chain Saw 460
How to remove top end husqvarn 460 chain saw
Location of bolts that hold cylinder to engine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 188 Answers
To remove the top end, the carburetor must be removed as well as much of the plastic casing. The cylinder head bolts install from below. There are 4 bolts holding the cylinder assembly.
Posted on Feb 03, 2016
5 Suggested Answers
  • 4088 Answers
SOURCE: husqavarna chain saw wont start it all checks out good its a 460
Remove the spark plug and pull the engine through a number times to expel any accumulated fuel from the crankcase and cylinder. Hold the throttle wide open and choke off while doing this. Lay the spark plug on engine metal (wire attached) and check for spark--it should be blue and snappy. If the engine has a compression release, it may be plugged with carbon--clean or replace. Check the air cleaner and muffler for any plugging. With luck, this should get you running. Hope this helps!
Posted on Apr 29, 2010
  • 78 Answers
SOURCE: husqvarna 460 rancher saw- chain brake is tripped
Pull back on the chain brake, this will release it.
Posted on Nov 15, 2010
  • 26 Answers
SOURCE: piston seizure in Husky 359 chain saw-how to
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Posted on Sep 21, 2011
MOTORWIZJ
  • 1338 Answers
SOURCE: Husqvarna Chain saw 460 rancher chain brake problems
THERE LINKED TOGETHER SOUNDS LIKE, TAKE THE SIDE PLATE OFF THE SAW AND BLOW IT OUT WITH COMPRESSED AIR, THIS I THINK WILL SOLVE THE PROBLEM . IT'S JUST A GOOD IDEA TO BLOW OUT THE SAW AFTER EVERY USE .THINK SAFETY !1. JAY THE POOL PUMP GUY IN LONGWOOD FL
Posted on Feb 03, 2012
How do i reset the timing on 2001 2.7l concorde if the chain was replaced and the timing is off
Did you take pictures while removing the originals? It's always a good habit. Below are the instructions you need to follow. Your own pics are very helpful when doing a big job like this.
  1. Disconnect negative battery (1) cable.
  2. Drain cooling system.
  3. Remove upper intake manifold.
  4. Remove cylinder head covers, crankshaft vibration damper, and timing chain cover.
CAUTION: When aligning timing marks, always rotate engine by turning the crankshaft. Failure to do so will result in valve and/or piston damage.
117014297
  1. Align crankshaft sprocket timing mark to mark on oil pump housing (2). The mark on oil pump housing is 600 ATDC of #1 cylinder.
CAUTION: When the timing chain is removed and the cylinder heads are still installed, DO NOT rotate the camshafts or crankshaft without first locating the proper crankshaft position. Failure to do so will result in valve and/or piston damage.
117016938
  1. Remove primary timing chain tensioner retainer cap (2) and tensioner (1) from right cylinder head.
117016939
  1. Disconnect and remove camshaft position sensor (4) from left cylinder head.
  2. Remove timing chain guide access plugs (3) from cylinder heads.
NOTE: When camshaft sprocket bolts are removed, the camshafts will rotate in a clockwise direction.
  1. Starting with the right camshaft sprocket, remove the sprocket attaching bolts. Remove camshaft damper (1) (if equipped) and sprocket.
  2. Remove left side camshaft sprocket attaching bolts and remove sprocket.
  3. Remove lower chain guide (7) and tensioner arm (8).
  4. Remove the primary timing chain (5).
  5. Remove crankshaft sprocket (6).
INSTALLATION
117016940
  1. Inspect all sprockets (4,9,11) and chain guides (2,5,10). Replace if worn.
  2. For crankshaft sprocket installation procedures Refer to CRANKSHAFT SPROCKET.
  3. If removed, install right and left side short chain guides (11). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
  4. Align crankshaft sprocket timing mark to the mark on oil pump housing (3).
NOTE: Lubricate timing chain and guides with engine oil before installation.
  1. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links (1).
117016941
  1. Lower the primary chain with left side sprocket through the left cylinder head opening.
NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
  1. Loosely position left side camshaft sprocket over camshaft hub.
  2. Align timing (plated) link to the crankshaft sprocket timing mark (3).
  3. Position primary chain onto water pump drive sprocket (10).
  4. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain (8) and loosely position over camshaft hub.
  5. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
  6. Install left side lower chain guide (2) and tensioner arm (5). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
NOTE: Inspect O-ring on chain guide access plugs before installing. Replace O-ring as necessary.
  1. Install chain guide access plugs to cylinder heads. Tighten plugs to 20 Nm (15 ft. lbs.) .
NOTE: To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
117016942
  1. Purge oil from timing chain tensioner using the following procedure:
    1. Place the check ball (2) end of tensioner into the shallow end of Special Tool 8186 (3).
    2. Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
117016943
  1. Reset timing chain tensioner using the following procedure:
    1. Position cylinder plunger (4) into the deeper end of Special Tool 8186 (3).
    2. Apply a downward force until tensioner is reset.
NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball.
CAUTION: Ensure the tensioner is properly reset. The tensioner body (4) must bottom against the top edge of Special Tool 8186 (3). Failure to properly perform the resetting procedure may cause tensioner jamming.
NOTE: Inspect the tensioner O-ring (2) for nicks or cuts and make sure the snap ring (1) is correctly installed, replace as necessary.
117016944
  1. Install the reset chain tensioner (1) into the right cylinder head.
  2. Position tensioner retaining plate (2) and tighten bolts (1) to 12 Nm (105 inch lbs.) .
117016945
  1. Starting at the right cylinder bank, first position the camshaft damper (1) (if equipped) on camshaft hub, then insert a 3/8 square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 inch lbs.) .
  2. Turn the left side camshaft by inserting a 3/8 square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 inch lbs.).
  3. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
117016946
  1. Activate the timing chain tensioner by using a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then release the tensioner arm. Verify the tensioner is activated (extends).
117016947
  1. Install camshaft position sensor (2) and connect electrical connector.
  2. Install the timing chain cover, crankshaft vibration damper, and cylinder head covers.
  3. Install upper intake manifold.
NOTE: After installation of a reset tensioner, engine noise will occur after initial start-up. This noise will normally disappear within 5-10 seconds.
  1. Fill cooling system.
Mar 27, 2013 | 2001 Chrysler Concorde
Need diagram how to install timing chain 2004 Malibu overhead cam
Procedure is pasted below. Please let me know if you have questions.
Removal & Installation2.2L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Drain the engine oil.
  4. Remove or disconnect the following:
    NOTE The timing chain has 2 matching colored links and 1 uniquely colored link.
    Negative battery cable, PCV hose, Fuel line bracket, Ignition coil and module assembly Ground strap from camshaft cover, Camshaft cover, Front fender liner, Accessory drive belt Crankshaft balancer pulley, Accessory drive belt tensioner, Front cover-to-water pump bolt Remaining front cover bolts, Front cover
  5. Rotate the engine until the crankshaft sprocket mark aligns with the matching colored link (2) at the 5 o-clock position.
  6. Confirm that the INT diamond on the intake camshaft sprocket is aligned with the uniquely colored link at (1) the 2 o-clock position.
  7. Confirm that the EXH triangle on the exhaust camshaft sprocket is aligned with the matching colored link (3).
  8. Remove or disconnect the following:
    NOTE Use a 24 mm wrench to hold the camshafts to prevent them from turning.
    Timing chain tensioner, Fixed timing chain guide access plug, Fixed timing chain guide Upper timing chain guide, Exhaust camshaft sprocket, Timing chain tensioner guide Intake camshaft sprocket, Timing chain through the top of the cylinder head Crankshaft sprocket
    Fig. Lining up the crankshaft sprocket mark with the colored link in the 5 o-clock position (2).
    Fig. Aligning the intake camshaft sprocket mark with the colored link in the 2 o-clock position (1).
    Fig. Aligning the exhaust camshaft sprocket (3).
To install:
  1. Install the crankshaft sprocket with the timing mark in the 5 o-clock position.
  2. Assemble the intake camshaft sprocket to the timing chain with the timing mark lined up with the uniquely colored link (1). Hand tighten a new intake camshaft sprocket bolt.
  3. Lower the timing chain through the opening in the cylinder head.
  4. Route the timing chain around the crankshaft sprocket and line up the first marching colored link (2) with the timing mark on the crankshaft sprocket.
  5. Install the exhaust camshaft sprocket with a new bolt loosely onto the exhaust camshaft.
  6. Align the timing mark on the sprocket with the last matching colored (3).
  7. If necessary, align the camshaft as follows:
    1. Using a 24 mm wrench, first turn the intake camshaft until the alignment feature on the back of the camshaft sprocket seats in the notch in the front of the intake camshaft.
    2. Turn the crankshaft 45 degrees in either direction.
    3. Turn the intake camshaft to the appropriate location.
    4. Turn the crankshaft back to top dead center (TDC).
  8. When the sprocket seats in on the camshaft, tighten the sprocket bolt hand tight.
  9. Verify all of the colored links and the appropriate timing marks are still aligned.
  10. Install the fixed timing chain guide. Tighten the bolts to 133 inch lbs. (15 Nm).
  11. Install the upper timing chain guide. Tighten the bolts to 89 inch lbs. (10 Nm).
  12. Using a 24 mm wrench to hold the camshafts, tighten the camshaft sprocket bolts 63 ft. lbs. (85 Nm) plus 30 degrees.
  13. Measure the timing chain tensioner from end to end. A new tensioner should be supplied in the fully compressed non-active state. A tensioner in the compressed state will measure 2.83 inches (72 mm) front end to end. A tensioner in the active state will measure 3.35 inches (85 mm) from end to end.
  14. If the timing chain tensioner is not in the compressed state, perform the following steps:
    1. Remove the piston assembly from the body of the timing chain tensioner by pulling it out.
    2. Install the bottom half of the Tensioner tool J-45027-2 into a vise.
    3. Install the notch end of the piston assembly into the bottom half of the tensioner tool.
    4. Using the top half of the Tensioner tool J-45027-1, turn the ratchet cylinder into the piston.
    5. Install the compressed piston assembly back into the timing chain tensioner body until it stops at the bottom of the bore. Do not compress the piston assembly against the bottom of the bore.
  15. Install the timing chain tensioner assembly. Tighten to 66 ft. lbs. (75 Nm).
  16. Release the timing chain tensioner by compressing it approximately 0.08 inches (2mm). Feed a rubber-tipped tool down through the cam drive chest to reset on the cam chain. Give the tool a sharp jolt diagonally downwards to release the tensioner.
  17. Install the timing chain oiling nozzle.
  18. Install the timing chain guide bolt access hold plug with silicone sealant on the threads. Tighten the plug to 59 ft. lbs. (90 Nm).
  19. Install or connect the following:
    Camshaft cover. Tighten the bolts to 89 inch lbs. (10 Nm). Front cover with new gasket. Tighten the bolts to 18 ft. lbs. (25 Nm). Accessory drive belt tensioner. Tighten the bolts to 33 ft. lbs. (45 Nm). Crankshaft balancer pulley using a new bolt. Tighten the bolt to 74 ft. lbs. (100 Nm) plus 75 degrees. Accessory drive belt, Front fender liner, Ground strap to camshaft cover Ignition coil and module assembly, Fuel line bracket, Air intake assembly, Negative battery cable
  20. Refill the cooling system to the correct level.
  21. Refill the engine with oil to the correct level.
  22. Start the engine and check for leaks.
    Fig. Compressing the timing chain tensioner-2.2L engine.
Oct 06, 2011 | 2004 Chevrolet Malibu
SAW AND BLADE SMOKING
Not enough oil getting to the chain, check the oil flow, hold the tip of the bar close to a tree stump rev the saw, you should see a good line of oil on the stump srayed from the end of the bar, if not the machine is not oiling, drain the oil tank, fill with a suitable cleaning fluid, give it a good rinse out, and try again.
Jul 18, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Need to remove cilinderhead from a chevrolet trailblazer 2003
below are the instruction you well need to remove head .....good luck Removal Procedure
  1. Remove the air cleaner element.
  2. Remove the air cleaner outlet resonator. .
  3. Remove the powertrain control module (PCM) and engine wire harness bracket and related hoses and connections.
  4. Remove the generator.
  5. Remove the intake manifold.
  6. Remove the exhaust manifold. Do not remove the exhaust pipe from the manifold. Only have the manifold pushed off to the side of the engine.
  7. Position the A/C line out of the way towards the front of the vehicle.
  8. Disconnect the following cross-vehicle engine wiring harness connectors:
  9. • Engine coolant temperature sensor • Manifold absolute pressure (MAP) sensor • Ignition coils • Harness clamps at power steering pump • Wiring harness fastener at the right front inner fender • Throttle body • Camshaft sensors • Camshaft actuators • Fuel rail • Heated oxygen sensor (HO2S)
  10. Set aside the cross-vehicle engine wiring harness on the left side of the vehicle.
  11. Remove the camshaft cover.
  12. Partially drain the cooling system.
  13. Before performing one of the top dead center (TDC) procedures, break loose both the exhaust and intake camshaft sprocket bolts. Use a 25 mm (1 in) open end wrench on the camshaft hexes to hold the camshaft from turning. DO NOT remove the bolts.
  14. Perform one of the following methods for the service timing procedure.
  15. First Method--Rotate the engine clockwise by hand to TDC on the compression stroke by using a piston TDC indicator tool and/or dial indicator in the number 1 cylinder.
  16. First Method (continued)--The TDC indicator tool graduation marks on the shaft should note top of the piston stroke.
  17. First Method (continued)--When the piston is at TDC, the flats at the rear of the camshafts will be facing up and level when using a straight edge across the camshaft flats.
  18. Second Method--Rotate the crankshaft in the engine rotational direction clockwise until the number 1 piston is at TDC on the compression stroke. The word Delphi on the exhaust camshaft position actuator will be parallel with the cylinder head to cam cover mating surface. When the piston is at TDC, the flats at the rear of the camshafts will be facing up and level when using a straight edge across the camshaft flats. A 0.005 inch feeler gauge should not slide under the straight edge (1).
  19. Use a white paint pen or equivalent to place a reference mark on the harmonic balancer to the front cover for alignment purposes.
  20. Lower the vehicle.
  21. Important: If the timing is correct (TDC compression stroke number 1 cylinder), the camshaft flats will be in the up position.
    Install J 44221 to the back of the camshafts.
  22. Remove the upper timing chain guide to the cylinder head.
  23. Clean the timing chain and gears with brake cleaner or suitable solvent. Use a white paint pen or equivalent to place a reference mark on both timing gear sprockets and the timing chain to mark location prior to disassembly. It is recommended that the paint marks be in the 12 o'clock position.
  24. Install EN-48464 . It is important to install the tool with the proper orientation and to ensure that it is seated square against the timing chain and against the timing cover center bolt.
  25. The narrow ramp of the wedge tool needs to be placed so that it faces the timing chain.
  26. The wedge tool should be lightly seated using a couple of very light taps with a small plastic or brass hammer. The wedge tool will be fully seated against the tensioner after it moves about 25 mm (1 in).
  27. Once the tool is correctly installed, unscrew the handle and remove the handle
  28. Remove both upper cylinder head access hole plugs from the front of the cylinder head.
  29. Remove the 1 long and 2 short cylinder head bolts next to the exhaust and intake timing chain tensioner shoes and discard the bolts.
  30. Remove both upper timing chain tensioner shoe bolts.
  31. Remove the exhaust and the intake camshaft sprocket bolts. Discard the bolts.
  32. Carefully remove the exhaust and intake camshaft sprockets with the timing chain from the exhaust and intake camshafts. The illustration shows the exhaust camshaft sprocket already removed.
  33. Remove the sprockets from the chain, tie a piece of mechanic's wire on the timing chain and let it drop.
  34. Before removing the cylinder head bolts, use a drift punch and hammer to shock the bolts. This will ensure that the cylinder head bolts will not strip out the threads in the engine block or break. If a bolt breaks during engine disassembly, EN-47702 is available to assist in the removal of the remaining bolt segment.
  35. Remove the cylinder head bolts. Discard the bolts.
  36. Remove the cylinder head.
  37. Place the cylinder head on a flat, clean surface with the combustion chambers face up, in order to prevent damage to the deck face.
  38. Remove the cylinder head gasket.
  39. Discard the gasket.
  40. Remove all remaining gasket material from the engine block.
  41. Inspect the cylinder head gasket mating surface on the engine block.
  42. Clean and inspect the cylinder head.
  43. Disassemble the cylinder head if necessary.
May 23, 2011 | Chevrolet TrailBlazer Cars & Trucks
Timing chain noise
Yes, that would sound about rite the xl125 r along with all the single hondas are pron to chain noise, easy fix, remove alternator l/ h cover, also timeing cover on cylinder head, mark plate and case with screwdriver for exact replacment, undo 10 mm bolt in end of camshaft and remove the atu unit take care not to loose the locating pin from the camshaft
Remove the pin if loose, undo the 2cover bolts and remove the cam cover, locate the timeing mark on the cam wheel and turn the engine until the mark on the wheel aligns with the mark on the case at about 12 oclock, then check the position of the lower pully and mark this, undo the top wheel bolts securing it to the camshaft, gently pull the wheel of the cam slightly and then hook the chain off the wheel, the cam wheel will now pass through the case opening,the cam chain will now come off the lower wheel, and can be pulled up and out over the end of the camshaft, and replacment would be in reverse order, checking alignment of all previously noted marks and security of all fixings before rotating the engine with a spanner and check it completes a full 360 degres before atempting to use the kickstart, the tensioner is addjusted by removing the top nut from the tensioner located on top of the crankcase lh side at the rear of the cylinder, then undo the 14 mm tensioner bolt, you could try first off screwing a 4mm screw into the tensioner, where the 10 mm bolt is removed, undoing the 14mm and pulling up on the screw with a pliers while tightening the 14mm locking device, as the tensioner is automatic this would be a manual addjustment and may remove the exsess slack
Feb 27, 2011 | 1985 Honda XL 125 R
Trying to put chain and saw together
If the saw has a chainbrake make sure it is de activated by pulling the hand guard fully to the top handle, you should hear an audible clip when it locks, remove the the bar nut/nuts and remove the side cover, if the chain adjuster is in the cover screw it right back, if the adjuster is in the crankcase screw it right back, place the guide bar onto the bar bolts, loop the chain over the sprocket and lay it around the guide bar with the cutters on the top of the bar facing away from the saw, if the adjuster pawl is in the crankcase locate it into the adjuster hole in the guide bar, now re fit the side cover, if the adjuster pawl is in the cover make sure it locates into the adjuster hole in the guide bar, re fit the bar nut/nuts finger tight, screw the adjuster up until the chain sits snuggley around the whole guide bar, pull the chain around the bar manually with a gloved hand, this will make sure it turns freely and is correctly located in the sprocket, hold the end of the guide bar up and tighten the nut/nuts
Jan 23, 2011 | McCulloch Garden
How to get the clutch off on a 142 husky
  1. Turn off the saw and release the chain brake. The chain brake is the plastic handle located on the topside of the saw's body, and is between the bar and the throttle. With a gloved hand, spin the chain to ensure the brake is off.
  2. Use the wrench to loosen the bar nuts until they are finger tight. Use the flathead screwdriver to loosen the bar tensioner screw. This screw is located in between the bar cover's two metal posts, and can be reached through the small, round hole in the cover's center.
  3. Finish loosening the bar nuts and remove the bar cover. Take off the bar and chain; set them aside in a safe place.
  4. Unplug the spark plug from the rubber spark plug connector, located on the top of the saw's body. Push some of the chainsaw's starter chord string into the spark plug cylinder to block the piston from moving while taking apart the clutch.
  5. Remove the clutch assembly with the clutch socket wrench. Husqvarna chainsaw clutches are left-locking nuts, so you will need to turn the bolt clockwise to loosen it. Tap on the socket's handle with a hammer if the bolt won't loosen.
  6. Remove the bolt and pull off the clutch cover, clutch spring and clutch drum. Replace these parts if they are chipped, warped or heavily worn.
  7. Follow these steps in reverse order to reassemble the clutch.
Nov 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
Husqavarna chain saw wont start it all checks out good its a 460
Apr 29, 2010 | Husqvarna Chain Saw 20" Bar
Timing on 4.7 help
INSTALLATION
  1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin (Resetting Secondary Chain Tensioners).
  2. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
  3. Install right side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.). NOTE: The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
  4. Install the left side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
  5. Install left side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.).
  6. Install the right side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.).
  7. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8515 to hold chains in place for installation (Installing Secondary Timing Chains on Idler Sprocket).
  8. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket (Timing Chain System).
  9. Lubricate idler shaft and bushings with clean engine oil.
  10. Install all chains, crankshaft sprocket, and idler sprocket as an assembly (Installing Idler Gear, Primary and Secondary Timing Chains). After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or the equivalent, This will maintain tension on chains to aid in installation. NOTE: It will be necessary to slightly rotate camshafts for sprocket installation.
  11. Align left camshaft sprocket “L” dot to plated link on chain.
  12. Align right camshaft sprocket “R” dot to plated link on chain. CAUTION: Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over-torque of bolt resulting in bolt failure.
  13. Remove Special Tool 8515, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  14. Verify that all plated links are aligned with the marks on all sprockets and the “V8” marks on camshaft sprockets are at the 12 o'clock position (Timing Chain System). CAUTION: Ensure the plate between the left secondary chain tensioner and block is correctly installed.
  15. Install both secondary chain tensioners. Tighten bolts to 28 N·m (250 in. lbs.). NOTE: Left and right secondary chain tensioners are not common.
  16. Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 34 N·m (25 ft. lbs.).
  17. Remove all locking pins (3) from tensioners. CAUTION: After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
  18. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left (Tightening Left Side Camshaft Sprocket Bolt) and right (Tightening Right Side Camshaft Sprocket Bolt). camshaft sprocket bolts to 122 N·m (90 ft. lbs.).
  19. Rotate engine two full revolutions. Verify timing marks are at the follow locations:
  20. Lubricate all three chains with engine oil.
  21. After installing all chains, it is recommended that the idler gear end play be checked (Measuring Idler Gear End Play). The end play must be within 0.10–0.25 mm (0.004–0.010 in.). If not within specification, the idler gear must be replaced.
  22. Install timing chain cover (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT / CHAIN COVER(S) - INSTALLATION) and crankshaft damper (Refer to 9 - ENGINE/ENGINE BLOCK/VIBRATION DAMPER - INSTALLATION).
  23. Install cylinder head covers (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION). NOTE: Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
  24. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 81 N·m (60 ft. lbs.) (Cylinder Head Access Plug Location).
  25. Install the oil fill housing.
  26. Install access plug in left cylinder head (Cylinder Head Access Plug Location).
  27. Install power steering pump (Refer to 19 - STEERING/PUMP - INSTALLATION).
  28. Install radiator fan shroud.
  29. Fill cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE).
  30. Connect negative cable to battery.
Jul 08, 2009 | 2000 Dodge Durango
Husqvarna 20" 60cc Rancher Chain Saw  460 Logo
43 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
