Question about Hitachi 61SBX59B 61" Rear Projection Television
No power 615bx59b
No power.. power cord and outlet checked. ac fuse okay. procedure to reset power protection completed with no results. still no power.
Wiring diagram for a 1988 sunline travel trailer.some of the light switches and outlets have no power going to them.what could be the problem?
Your trailer has two electrical systems, 12v and 120v. The 12v system has a battery and perhaps a converter/charger to power it. The 120v system must he hooked up to 'shore power.' Both systems have their own protection. The 12v system has a fuse panel, check for power at each fuse. 12v wall switches are often smaller and don't look like typical 120v switches like in a house.
The 120v system has a breaker box and circuit breakers. Reset each breaker by turning off then on again. In addition, the 120v outlets might have a GCFI outlet near a sink. It often is wired first in a breaker circuit, thus giving GCFI protection to other outlets in the circuit. Test the GCFI and make sure it clicks off and can be reset.
May 01, 2017 | RVs
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Hi i have a 40inch bush tv my partner was using this for his computer screen last night like he does all the time but for some reason it turned itself off and now wont turn back on. The standby button is...
Is there anything power signal lights?If there is no signal power lights,it is totaly dead set no power.First step is to check the power outlet,then the AC cord if there's a ac power.If the AC cord is good,check the fuse,located at the power supply.Replace same value of fuse if busted.Try this sugestion or procedure.Thankss...
Aug 26, 2011 | Bush Televison & Video
No power to TV
First thing to do if your television have no power is check the power outlet,then the AC cord continuity.If the ac cord have power supply,check the fuse,maybe the fuse is busted.Its is located at the power supply.So try to remove and open the back cover of your TV and look the power supply and replace the fuse if busted.Replace same value of fuse.Try this procedure,hope it will help you.Thanks..
Aug 26, 2011 | Panasonic Televison & Video
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
I had a fire in the microwave and now it doesn't turn on. Is there a reset button or do I have to go buy a new one? cbierke@gmail.com
It sounds like an internal fuse has blown. Unplug unit and carefully open the top cover to provide access to the A.C. power cord entry point. Hopefully the fuse is located in that area and is the older style 1/2" long glass or ceramic body with metal endcap on each end. ONLY REPLACE WITH A FUSE THAT HAS IDENTICAL ELECTRICAL RATINGS! After replacing the fuse and top cover reconnect the unit to the A.C. outlet and check to see if it is still dead. Still dead = repair shop time.
NOTE: Use a "fused" A.C. outlet strip (usually 6 outlets with circuit breaker) for your "after fuse replaced" testing. This gives you additional protection against accidentally tripping a breaker in your homes electrical panel.
Oct 19, 2010 | Maytag Microwave Ovens
My Dometic refrigerator electric position won't cool, could it be the fuses? If so, where are the fuses? So I can check them out. Thank you
Hi Patti,
If you are sure that your controls are set to cool in electric, then the rest of this will apply to the backside of the fridge. Double check, with a table lamp or simiiar, that you have power to the outlet that the fridge plugs into. This outlet is generally a protected outlet by a GFCI outlet located in the kitchen or bath areas. If the lamp works on the outlet, keep going. If not, reset GFCI and/or check our circuit breaker panel.
There are fuses on the Power Module, located on the back of the fridge, under a plastic rectangular housing. The DC fuse will be 3 Amp the AC fuse will be 5 Amp. If you are getting any kind of lights on the front, then the DC fuse will be okay. If your AC fuse is blown, then you need to check for a shorted heater. Disconnect the heater leads (after unplugging the fridge from AC). These will be the leads at J7 and J8 terminals. Unplug the leads, and use a multimeter to measure resistance between each lead. You should have approx. 44 ohms, +/- 10%. Also measure each lead to the case of the heater (follow the wires to the chimney). Any continuity reading here indicates a heater that is shorted to the case.
Good Luck!
Aug 16, 2010 | Dometic RM2852 Refrigerator
The toaster does not heat and it's only 6 mos. old.
1. check outlet where you plug in your toaster with lamp or vacuum.
jiggle plug of lamp or vacuum while plugged in to check for bad outlet.
if lamp or vacuum do not work, check breaker panel/fuse box for tripped breaker/blown fuse.
if breaker/fuse okay, replace outlet.
if lamp or vacuum work okay, go to next step
2. plug toaster back into outlet, jiggle plug, then jiggle cord at plug, then jiggle cord at toaster.
this checks for intermittent power cord.
if cord okay, check that the toaster lever or toast basket are not blocked from going completely down.
might be a bit of bread, muffin, bagel that blocks the basket.
if all okay, you need other solutions.....
Jul 09, 2009 | Back to Basics Kitchen Appliances - Others
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Microwave oven
Check the wall AC outlet by using a meter or another electrical appliance such as a table lamp. If no power there replace the fuse or reset the circuit breaker.
Does your microwave light up when you open the door?
If not, it could be a bad power cord, on/off switch AC cord or fuse.
Check these first.
If you cannot solve the problem, you'll probably need service.
Hope this helped.
Mar 25, 2008 | Panasonic NN-P794SF Microwave Oven
Hitachi 61SBX59B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
