Question about Video Cameras
JVC DV800GU Cassett stuck halfway in while loading new tape
    Problem Solver:
  • 5 Answers
Try taking in out with a sharp object, while off
Posted on Jun 18, 2009
Cassette plays in fast motion, sounds like Alvin and the chipmonks?
in my life time i fixed over 45000 cassette players... it is either one of 2 things... 1 there s tape stuck on the flywheel, just remove it and clean the fly wheel with alcohol. if it clean and no take stuck on it, then it is the mother itself, there is adjustment on it , but likely the servo system is damages so it will need to be replaced, once you install a new one you will need a speed adjustment tape. like 333 HZ or 1 kHZ and a frequency counter to calibrate the new motor
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Sep 14, 2014 | RCA RCD175 port cd boombox w cassett
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
Won't turn on video tape stuck halfway inside
Stuck halfway inside could indicate that the actual tape is stuck in the capstan/heads. It may have never fully released from the mechanisms and returned to casing. Basically it ate your tape. You could try taking the cover off the unit and manually and carefully remove jammed tape. Unplug the unit first. Hope this is helpful.
Apr 29, 2010 | Sanyo DVW-7200 DVD/VCR
Please help me, I have a 4 Runner 2003 that has a JBL CD Player and a Cassett player in one built in the dash. Both are not working: The CD Player keeps flashing (Error 3) when ever I put a CD in...
did the error code start with the tape getting stuck? i have heard that if you disconnect the battery for 5-10 minutes it will reset the radio but make sure you have a code for it to unlock it it the radio has security. they say it starts working again if you do this. again this is just what i have heard a toyota tech say when i worked there. it may be that it knows it has a problem with the tape and keeps it inop, as far as getting the tape out, it either breaks the tape or the tape player or both. i worked at a car stereo shop for 10 years and very rare for both to survive.
Oct 28, 2009 | JBL Car Audio & Video
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
Some of my old cassett tapes slow down & speed ''wobbles'' when playing. Is there any way to fix this?
The only thing you can do is take the tape out of the cassette and place it in a modern cassette case. Just buy new blank tapes and discard the new tape inside. If that doesn't work and it's not your player causing the problem then it's due to the tape itself.
Apr 04, 2009 | Audio Players & Recorders
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
How do I close the cassett holder? (JVC GR-D70 comcorder)?
man just try pushing that place by a small support on its lower side. ( imean below... just the opposite side where it is told to "push here". i hope if you didnt broke its locking mechanism, it will work..
Oct 11, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Video Cameras Logo
113 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
