Question about Craig CLC501 15 in. TV
How to hook wall mount - Craig CLC501 15 in. TV
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
I need brackets to mount it to a wall
do a search on eBay for
"garage storage wall hooks"
as for the charger you might need to put it in a bag to hook it up.
that will be the cheapest way.
hope that helps
mark
Aug 29, 2014 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
I don't know how to take my Gatco 4515 "Tiara" Robe Hooks off the door now that I'm moving. Please help. Thank you.
I'm not 100% sure about this model, but I have a similar hook by another brand. Here's how mine is removed:
When you look at the hook, there's a small hole at the 6 o'clock position, (pointing down, right next to the wall.) This hole is actually a set screw that can be turned with a small hex-key (aka allen wrench)
thomascha103_7.jpg The size needed is pobably about 2 mm, or 1/16 in.
Turn the set screw counter-clockwise for a few turns to loosen the hook from the mounting bracket. When the set screw is backed out far enough, the hook will detach.
After he hook is removed, you'll be able to see the mounting bracket that is screwed into the wall. Remove the screws with a screwdriver, and take the mounting bracket with you. You'll need it to attach the hook to the new wall.
If there is no set screw or hole visible from any side, then your Gatco hook might be removed from the mounting bracket by twisting the entire hook counter-clockwise.
If anyone else out there has experience with this particular brand, please chime in and correct me if I'm wrong.
I hope I've been helpful. Good luck.
Jan 19, 2011 | Gatco 4515 Tiara Robe Hook Bathroom...
A blower you can hook up to the dyna-glo wall mount heater
only if there is one for the particular model heater you have ck with dealer in your area
Nov 24, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Wall Mounting
Slide it all the way up and out, turn it upside down and slide it back in.
Sep 06, 2008 | GE 29267GE3 Corded Phone
Wall mounting
According to the manufacturer (and numerous websites selling this TV) there is no provision to mount this TV by normal industry standards. It should state clearly on the box or manual what the mounting standard is if it is mountable, and in this case its not. Sorry.
Mar 23, 2008 | Westinghouse LTV-19W3 19 in. LCD...
Rear speakers
THE 4 WIRES SHOULD BE FROM THE REAR SPEAKERS THEY GET WIRED INTO THE SURROUND SPEAKER OUT POSTS ON YOUR AMP (MAKE SURE YOU DO NOT GO INTO SURROUND BACK THIS IS FOR 6.1 AND 7.1 SYSTEMS).WHAT ARE THE WALL UNITS? NEED MORE INFO TO TRY TO HELP.
HOPE THIS HELPED A BIT.
CABLE GUY
Feb 13, 2008 | Onkyo TX-SR605 Receiver
Craig CLC501 15 in. TV Logo
19 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
