This problem should be removed because:
Problem with Dell 2300MP Multimedia Projector
No power to my dell 2300mp
No power. The green lights on the buttons don't even light up.
I tried a different power cord with no results.
Solutions (2)
Best Solution
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
please check power fuse inside(from2-5amp)
flasing red light
Last night my xr-10x-l worked fine Shut down fine as I remember? . To day all I have IS A flashing red light. I pulled the bulb it looks ok...
dell 2300mp projector
I have a dell 2300mp projector. I replaced the lamp with a brand new one. I plug the power cord and the green light on the power...
FAST BLINKING GREEN & WON'T POWER ON
Just as I went to my theater room to verify the type of flashing LED I had (fast green blink, about 5 blinks per sec.), I can't believe...
Optoma 719, can't get lamp and fan to turn on.
After plugging into the power, the green light flashes (in standby). I hit the power button and the green light turns solid green, but the...
Add Your Solution
Problem with connecting with computer, always...
all it is doing is searching for signal. What do i need to do to fix this problem?
Dell 2300MP flickers colors and shuts off
I just bought a Dell 2300MP and when plugged in and turned on it functions normally. However, after around a minute it...
after a few min. the projector starts to flicke...
after a few min. the projector starts to flicke then stops then the screen turns red and starts to flicker again and so...
Fix-O-Meter
2,284
2,284 people viewed this problem
- 6 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Dell Multimedia Projector Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
