Question about Tascam DP01 All-In-One Recording Package Microphone
Cant find master while exporting - Tascam DP01 All-In-One Recording Package Microphone
I need help in Groupon, I am using ShipStation and I cant retrieve my orders due to them being marked as "exported". How come they are being marked as exported when I'm not exporting them?
exported is a term used by the company that exports items
to stop confusion they use the single term export as meaning sent or dispatched as they can be sent or dispatched outside the country where they are exported
Nov 09, 2017 | Computers & Internet
How to export in tally 7.2
This applies to Tally 7.2 and above.
1. You can export only registers and not masters
2. In any view register mode the export / import option becomes availble.
3. Click export.
4. Tally prompts you for a file name. The default name is always Tally.txt.
5. Pl rename the file to represent the ledger you are exporting else Tally will over write an existing file.
6. Tally will always save the file in the same drive / folder where Tally data resides. You cannot change this.
7. The file saved is the CSV file.
8. Open this file with Excel and map the fields.
Jan 20, 2015 | Tally Office Equipment & Supplies
Cant transfer the master from tascam to computer
I'm assuming this is a Tascam recorder you're refurring to. What model is it, and what operating system are you using on your computer. First off, don't connect the usb cable to the computer until your Tascam Recorder in in USB Mode. I have the Tascam DP-01. With it, after making the master recording, make sure the master light is off, and not flashing. In the menu under WAVE, select Export Master and press enter. If anything is running, or the master light is lit, you will get an error. After the song is saved to the FAT partition, select DISK in the menu and scroll down to USB Open/Close and press YES/Enter. You'll be asked if you are sure. press Enter/Yes again to go into USB mode. Now plug in the USB cable. Use Windows Explorer, or what ever file navigation program is on your computer. (Not Internet exploere, but windows exploere.) Your Tascam will be seen as Removable Media when viewed from your computer. I have a DP-01, and it shows on my computer as DP-01. You'll find a few folders viewable on your recorder. One of them is called WAVE. You'll find your Exported Master in this folder. Copy it to a folder on your computer. When finished, if you're using windows, then use the Safely Remove Media function in the system tray where the clock is to disconnect from the Tascam safely. Then unplug the USB cable and press NO/Exit on your Tascam recorder to exit USB mode. I hope this helps. Have a wonderful day.
Jan 08, 2015 | Tascam Audio Players & Recorders
Tascam DO-02 Master will not light and cannot export tunes to CD for burning. Is there a short cut.?
You might want to post this question in a different section. This is the computer section.
Jun 28, 2012 | Tascam DP-02 8-track Digital Portastudio...
Deleting exported masters
Go to Songs menu, highlight a song, press enter twice.
Aug 18, 2009 | Tascam DP01 All-In-One Recording Package...
How to get masters from tally 9 to tally7.2
just export your masters in the xml format. Thn import in the required version using the same format.
Jul 27, 2009 | Tally Line Matrix T6050 Printer
Master Track too big to export.??
Im having exactly the same problem as you have/had..I cant Export the Master Track..It says "Too Big", have you been able to solve it?
Best Wishes
Steve
Mar 30, 2009 | Tascam DP01 All-In-One Recording Package...
i'm having the same problem... did you ever get it fixed?
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
Tascam DP-01 master track too big to export
Here is what I did to solve this issue:
1. Open up the USB connection on your DP-01 so that you may plug into a computer:
MENU-
Mar 24, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
43 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
