Question about Wasp Computers & Internet
Not scanning the red light comes on to scan the bar code but then makes a loud beeping noise and rejects the bar code
SOURCE: ms9520 buzzez and then will not scan
The Razzberry Tone is what I'm hearing. Acording to the trouble shooting I should return the unit for repair. Thanks for you help!
Posted on Jun 07, 2007
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
  • 25 Answers
SOURCE: barcode scanner won't scan.
You are likely experiencing power sag. If you are using a 15 foot usb cable try a 6 foot one instead. Even if that doesn't work it still could be power sag.
We sell an external power cable kit that replaces your USB cable with one that includes a power pack on the computer side.
The power pack provides the extra power you need.
It happens when it does becuase when the laser comes on more power is needed than available. The 5 VDC sags and the processor whigs out on you.
Posted on Jan 05, 2008
bluegreenash
  • 661 Answers
SOURCE: Can not scan Code 128 bar code
you should have a code book with the scanner setup barcodes in it, you need to enable code 128 by scanning the appropriate codes in the code book.
Posted on Sep 30, 2008
SOURCE: LS2208 beeps to ignolage the scan but puts no information
I don't know if this applies to the LS22208.
Symbol Support FAQ says;
A slow continuous flashing LED on the LS9208 indicates that the LS9208 has been put into “programming mode” and is ready to scan programming bar codes. Once the LS9208 is correctly programmed, the LED should stop flashing and remain on, indicating that the scanner is ready for use.
A fast, continuously flashing LED on the LS9208 indicates an internal problem. When the LED is in this state, the LS9208 laser is also shut off for regulatory reasons.
We support these for some big retailers. When they call with that issue 99/100 it's reseat the cable from the base of the scanner (or the system if accesible), no re-programming).
Posted on Jan 16, 2009
My 2009 auris has a loud noise from the front end and flashing check battery and check engine
You need a scan tool hooked up and the fault codes read that are recorded when these warning lights came on. That is the starting point to understand what has failed here.
May 19, 2017 | 2010 Toyota Auris 1.33
Check engine light on, backfires, loud rattling noise near muffle
find another shop..if the check engine light is on the code that caused the light to come should give you a direction to go to repair problem
Feb 17, 2010 | 2003 Isuzu Rodeo Sport
Light bar seems to be jammed
If the scanner is making a loud grinding noise when switched on or when attempting to scan, check the transportation lock is in the unlocked position.
Dec 02, 2009 | Office Equipment & Supplies
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
Copier beeps after scanning
Is this connected to a Vista computer? There might be a few extra things that need to be turned off permanently in the computers admin settings.
Nov 21, 2008 | Xerox Office Equipment & Supplies
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Computers & Internet Logo
61 people viewed this question
Top Wasp Computers & Internet Experts
David Payne
David Payne
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
