Question about NEC IP1NA-8KSU-A1 8 Slot KSU 0890000 Aspire
How do I reboot NEC Aspire IP1NA-8KSU-A1 Phone System
Why did Message notification stopped working?
A reboot should not loose any programing, in fact it should be done once a week, at least month
Mar 15, 2015 | NEC Aspire S Phone System W/4 PhoAll...
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Oct 02, 2014 | NEC Lands Phones
How do i stop flashing feature light on my nec dtp-8d-1a
Try rebooting your phone system. That helped with our system.
Jun 20, 2014 | NEC DTU 8D-2 Corded Phone
Nec 12txd phone not ringing and led indicator not working.
the only other setting that could turn the led off is if you enable blocking mode and you check disable led indicator (found by long pressing blocking mode in the pull down window). do you have any apps that could control the led lights like light manager? if so, try uninstalling it or checking its settings. if you dont have an apps like that, have you tried installing one to see if it works?
Feb 24, 2014 | NEC Aspire 22 Button Ip1na-12txh 0890043...
How to ping an nec phone system from an ip phone
Try disabling/enabling the SIP helper. (this change requires a reboot I think because it changes the kernel modules)
www.businesstelephonesystem.org/
Jun 21, 2012 | NEC Sv8100/sv8300 Itl-12de-1 bk Tel new
I need to know how to use the caller id on the NEC Aspirephone Model IP1NA-12TXH Tel (BK)
i need to know how tosee my call and delete then fron the phone
Aug 24, 2009 | Lands Phones
NEC 22B HF/Disp Aspirephone
http://www.askemergent.com/downloads/aspire-phone-qrg.pdf
http://www.askemergent.com/downloads/aspire-phone-feature-guide.pdf
Dec 26, 2008 | Radio Communications
NEC IP1NA-8KSU-A1 8 Slot KSU 0890000 Aspire Logo
166 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
