Question about Electrical Supplies
I have a Firman SPG6500E2 generator it wont start. IT has spark but i think it is not geting gas. It has a Ruixing carb. Sugjestions?
joboo1
  • 257 Answers
SOURCE: cranks fast but wont start
Hi, You did a good job of diagnosing your problem. Gas in bowl and dry plugs, starts with fluid, But, to quote you, "won't go through carb" . If you feel confident, you should disassemble and clean the carb, as that is going to be the problem. As a tip, if the genset is going to sit make sure to turn off the fuel flow to the engine and run till the engine dies. They do not like to sit any length of time with fuel in the carb. Good Luck, this should Fixya!
Posted on Mar 02, 2009
SOURCE: Coleman6250 Generator PM0545007 - Won't start/run.
Most gasoline engines need three basic things to run: proper air/fuel mixture, sufficient compression, and a properly timed spark. Check the easiest, cheapest things first, then check the "Gee, I forgot to turn on the gas" kind of things next, then work your way onwards from there.
Compression can be guesstimated with the proverbial thumb-over-the-empty-spark-plug-hole routine as you turn it over casually to check compression. If it doesn't blow your thumb out of position, you could have a hole in the piston (overheating response) or a stuck or damaged intake or exhaust valve.
Check for fuel flow by carefully disconnecting the fuel line to the carburetor and letting some run into a tin can (no styrofoam coffee cups, please). It should dribble freely. If not, you have to back-track the line and find out where the blockage is.
Spark is one that sounds like you've already tested (spark plug out of the cylinder head, hooked up and laying on the metal engine as you turn it over?) so check timing. You will probably need a manual for this test, although a good estimate is that the plug should fire just a wee bit before Top Dead Center position of the piston. Like I said, a manual comes in handy here.
From what you've mentioned, though, I'd start trouble-shooting at the fuel flow part first.
Good luck,
GRB
Posted on Jun 08, 2009
protek480
  • 1714 Answers
SOURCE: my champion 3500w generator stops all of a sudden
How long does it run? The 'oil pressure' switch will cause that....??
Posted on Sep 11, 2009
  • 142 Answers
SOURCE: 11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Posted on Jul 24, 2010
SOURCE: my 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Posted on Oct 26, 2010
My mini bike won't start unless you put gas where the spark plug is then it will run&idle but if you give it throttle it dies, it has a Ruixing carburetor with one adjustable screw and the idle screw no H...
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
8. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
9. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
10.. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
11. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
12. Faulty neutral, clutch lever, or kickstand safety switch.
13. Faulty fuel pump fuse or relay.
14. Tilt sensor needs a reset.
15. Security system not disarming alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://palmettospeedshop.com/RUIXING-CARB-REBUILD-KIT-BSP-1246-1
how to rebuild weed eater carb
Common Reasons Why My Pocket Bike Wont Start
Trouble Shooting Guide For Go Karts and Mini Bikes
Jun 01, 2016 | GAS Motorcycles
This is a new SPG6500e2 gen, that ha never worked, but had gas in the tank, that i eventually drained. i tried starting but to no avail. took the spark plug out, and attached to the plug wire and star
Baiscs - you need spark & fuel. FIrst you need to troubleshoot the ignition and if it sat for long with fuel, may need the carb cleaned too.
Jan 08, 2015 | Electrical Supplies
Mx-2721b gas generator carb kit
check for spark if spark squirt some starting fluid in carb dose it try to start or runs chang gas put fresh gas in it and seafoam carberator additve in it restart sameway let it run three tank fulls out then try to start it regular way if still dosnt wont to run rebuild carb this is how a shop would do it
Sep 02, 2014 | Electrical Supplies
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
Cranks but wont start
a host of reasons,
  • check if you have a spark buy removing ht lead from spark plug and holding near metal pat of engine while cranking, use insulated tool to hold lead, if spark thats ok
  • remove spark plug after lang cranking and smell if gas is present or plug is wet, if wet you are geting fuel
  • then ask again once you know what is not happening
  • has it electronic ignition
  • has it fuel injection or carbs
Dec 29, 2009 | 1987 Porsche 944
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Coleman powermate 2500 won't start and gas is leaking out of the
it sounds like mine I think it is the carb is clog up
I am still working on mine
Feb 04, 2009 | Coleman Powermate Proforce 2500 Generator
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
193 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
