Question about Sanyo PLC XW20 Multimedia Projector
How to reverse image
Rear projection
Reverse image
Find the switch for front projection/rear projection and set it to front!
Nov 25, 2011 | Lenovo M500 DLP Projector
MY JVC52Z575 (D-ILA) HAS A REVERSED BLUE IMAGE OF ANY YELLOW IMAGE
I have the same blue shadow with reverse image on my JVC HD-52Z575 Did you see what the problem on yours finally was?
Feb 20, 2011 | JVC HD-52Z575 52" Rear Projection...
Have a 46f500 hitachi projection television. Started out with a blue reversed arc hanging down on upper right. Now images are not focused, and red, blue and green are layered. Double images. I looked...
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
SD TECH
Jan 11, 2011 | Hitachi 46F500 46" Rear Projection...
How to turn the screen upside down for optoma projetcor
Found this on the InFocus site:
. You can reverse or flip the image for installation in a rear projection system or on the ceiling. To reverse or flip the image, press the Menu button on the keypad. Go to Main > Setup > System. Select the Rear checkbox or the Ceiling checkbox.
Jack - allprojectorlamp.com
Nov 25, 2010 | Office Equipment & Supplies
Projector is suspended from the ceiling upside down and so it is projecting upside down. How do i get it to project the images the right way up?
Since you have not mentioned the model it is diffficult if the option of reverse image is available on the menu. If so all you need to do is to scroll the menu and reverse/invert this image. If not the other option is to mount the projector with the projector fitted on a small stand in the same direction and not invereted. I hope you will search for this in the menu or in the rear panel. If not mount it in the actual position with a stand so that you can corrrect the height using the provided screw adjusters.Helpful? Good day
Jul 07, 2010 | Audio Players & Recorders
Why is the image reversed?
the projector has 4 settings: front, rear, ceiling, and ceiling rear. yours is set for rear projection. go into the menu and change it to front.
Jan 05, 2010 | Sharp Office Equipment & Supplies
Words are backwords
There ia likely a menu item as some projectors can be mounted upside down OR more likely, used for rear projection requiring reverse reading.
Look for a menu setup item to change this.
Dec 31, 2009 | ViewSonic PJ513DB Projector
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
PT-61LCX65 image reversed
Per panasonic's autorized tech website5.gif it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software5.gif upgrade.
Correct symptoms using part LSUQ0100 jig that comes with instructions. (operation takes 6 mins)
hope this helps.
Mar 24, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
JVC HD-52Z575
You both need to have a service center come out and reset the TV using the reset jig. This will correct the reverse image problem.
Feb 17, 2008 | JVC HD-52Z575 52" Rear Projection...
Sanyo PLC XW20 Multimedia Projector Logo
18 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
