Question about Toshiba 56HM66 56" Projection HDTV
No picture have sound but no picture lamp is new
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
My tv has sound but no picture?...
Is your lamp lighting? If not, then you need a new lamp. The lamp on this set has a 5 year warranty.
Mar 18, 2013 | Panasonic Televison & Video
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
LG DLP 52" - First the sound quit working, and only had the picture. Then a week later the picture quit also.
needs new lamp can order your slef and very easy to fix but you may also need a new ballast i woule take it to the local television repair shop to see about the sound if they ask about the picture tell them the lamp is in the mail if you order it through them and have them put it in your looking at an extra 30 to 50 dollars on the price ot the lamp
Jun 30, 2010 | LG 50PG20 50 in. Plasma HDTV
Picture comes and goes every few minutes on the rear projection LCD. I just recently installed a new bulb
How recent? That lamp should have a 30 or 90 day warranty. From what you are describing, the lamp is a dud. The cycling occurs when the lamp burner gap becomes too large after warm up. Listen closely to the sounds the TV is making when it is trying to bring the picture back up. Is there a buzz or gurgle sound coming from the lamp area? That's the TV trying to ignite the lamp. Get a new lamp or your money back for the one you installed. I hope this was of some assistance.
Apr 13, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Sony TV KF-60WE610 no Picture OR sound
check the tiny fan directly above the lamp for excess dust or if it spins at all
May 07, 2009 | Sony XL-2100U Projector Lamp for...
Toshiba 56HM66 56" Projection HDTV Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
