Question about Cuisinart DGB-625BC Grind-and-Brew 12-Cup Automatic Coffeemaker,
Cuisinart Grind & Brew 12-cup Automatic Coffeemaker stopped grinding the beans
It will brew coffee but not grind the beans anymore.
SOURCE: cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Posted on Oct 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I need operating instructions cuisinart automatic grind and brew
Here si the link to the user manual:
http://www.cuisinart.com/share/man/966_man.pdf
-Tha Mp3 Doctor
Posted on Jan 07, 2009
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
Have a cuisinart grind and brew. It's not working. The power light is blinking. No other lights will turn on and/or operate. Help.
This is caused by calcium building up within the machine. or insufficient power supply.This can cause injury.Make sure you troubleshoot it or see that power supply is enough.
Jul 21, 2016 | Cuisinart Grind-and-brew 12-cup Automatic...
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
HI,
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
Disassembly instructions - will not grind
watch this video http://video.cuisinart.com/video/video.php?s=cuisinart&t=demo&f=Cuisinart-DGB-650BC-Automatic-Coffeemaker its from cuisinart.com this may give u the complete answers and instructions to your problem,,,thank you for using fixya.com
Feb 11, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-625BC Grind-and-Brew 12-Cup Automatic Coffeemaker, Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
