Question about Apple Computers & Internet
Why does apple keyboard numbers delay
The numbers on apple Bluetooth keyboard are delayed when typed
SOURCE: delay print
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
Posted on Nov 27, 2007
SOURCE: Typing delay
Guest
After my whinge I did find the solution on the Dell forum support.
IT is a software conflict with Dell Media Centre. THe final comment on the page I found (do not have the link at hand) was from a Dell technician, his comment was to disable the PCMService in msconfig. Obviously Dell will not advocate to uninstall their own software but that was the other solution made by the other parties. I hope it works for you too!
Posted on Mar 13, 2008
  • 19 Answers
SOURCE: delay on keyboard when using with cubase and reason
this is because of the lantency of your sound card and your driver settings.
with 2 seconds,
that sounds like you're using a MME driver for your card.
try to change the driver to ASIO (if possible),
if not, change it to directX
you can do that that way:
- Open up Devices > Device Setup > VST Multitrack
- Drop-down the ASIO Driver settings on the right side of the screen
Posted on Mar 31, 2008
jitenok
  • 151 Answers
SOURCE: delay on typing words
Plz reinstall your's keyboard driver.
Posted on Apr 02, 2008
  • 125 Answers
SOURCE: Delayed keyboard response on Dell Inspiron E1705 Laptop
Is the mouse response sluggish as well during these times?
In most cases, it means the computer is busy with another process. The keys you press stay in the keyboard buffer until the CPU has time to process them.
Check your CPU busy time when this happens. In Windows XP, press ctl-alt-del to start the task manager, the select the processes tab to see if one process is tying up the system (by % of CPU), or press the performance tab to see CPU usage. If it is pegged at close to 100%, something is tying up the system.
Posted on May 13, 2008
Bluetooth Delay with Bose Mini & Macbook air
need instruction manual for wharfdale wcd-8000 compact disc digital seriel number 1021140766
Jan 27, 2014 | Bose Audio Players & Recorders
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 03, 2013 | Computers & Internet
When typing I can see letters with 3sec delay on the screen
This is not keyboard issue
if you are using windows xp , do the following
goto RUN
type %TEMP% enter
and delete all files, then restart computer
then you can check
thank you
Jun 30, 2011 | Compaq Keyboard
After i log in a cant use the keyboard for typing or inputting text
1. Go to System Preferences (it's usually in your dock)
2. Click on Keyboard.
3. Make sure your key repeat rate and delay until repeat is set to fast and short, respectively.
4. Open TextEdit.
5. Try typing there. If this still does not work, I suggest you to bring it to your nearest apple store since there might be a defect on your laptop.
6. As an alternative, click SHOW KEYBOARD & CHARACTER VIEWER IN MENU BAR.
7. Beside your battery/energy saver preferences and date would be a small box, click on that and it will show you SHOW KEYBOARD VIEWER for you to use your mouse/trackpad on.
May 20, 2011 | Apple MacBook Air
DELAY WHEN HITTING BACKSPACE FIX TYPING DELAY ON KEYBOARD
Hi, Try updating the keyboard driver for your machine by going to the manufaturers website and downloading the latest driver and install it on your system or might as well contact the manufatures tech support hotline for further assistance. hope this helps
May 19, 2010 | Computers & Internet
The keyboard is super sensitive making it impossible to type without many many errors. Is there any way to harden the keyboard?
In your control panel, you should be able to access keyboard settings and adjust the repeat delay rate for keystrokes as well as the delay before the repeat starts.
Apr 17, 2010 | Toshiba Satellite P105-S6104 Notebook
Typing delay
You can change the repeat delay times on your keyboard.
Click on the Control Panel then Keyboard icon. In the Speed tab you can change the Repeat delay and the Repeat rate settings to suit your requirements..
Feb 03, 2009 | Dell Inspiron 1501 Notebook
How do i turn off the delayed type on a ibm wheelwriter6
at the very top right of your keyboard there is a "print mode" key
press this key until the note in the left lower coner of the display says "char print"
however in delay print you can correct mistakes before you print - saves on correction tape
Nov 17, 2008 | IBM Wheelwriter 30 Typewriter
Delay on typing words
Apr 01, 2008 | Labtec 967307-0403 Keyboard
Dell Vostro 1500
There is a solution on these Dell Models.
Go to Start>RUN and type in MS Config
Go to the startup tab and uncheck the PCMServices.exe
Restart the computer, and it should fix it.
Paul
Mar 13, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
