Keeps running after shutting off-does not react to temperature co
Unplug the unit all shuts down, but replug in and seems like just the compresser is running and no fan, but the coils getting cold. if you turn it on all works, but it stays cold and does not go to fan mode when you regulate the temp control Thankyou
  • laurie_gary Jun 18, 2009
    But after letting it run the compressor will shut off after about 5-7 minutes and then it can come back on an hour or so later. So I just unplug unit. This does not happen all the time though!!!
  • 97 Answers
It is normal for the system to run on its own without being turned on...the compressor motor needs to cool down and will run in an unloaded state. feel the back of the unit while its running and you will notice the amount of heat the motor generates. let it run.
Posted on Jun 18, 2009
  • Chris Corbett
    Chris Corbett Jun 19, 2009
    it will do that if its too hot...the internal thermostat will turn it on to run the motor enough to cool it down.
Hot water heater keeps shutting off.
This sounds like a circuit board has a component that may be heating up and failing. When the unit is unplugged power is shut off to the circuit board, which will allow the component to cool down and start to work again. If this is the case then the component will fail completely at some time.
Dec 22, 2015 | Water Water Heaters
My dell inspiron 1525 keeps turning off and shutting down without me doing anything. why?
The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. Hope this helps.
Mar 29, 2010 | Dell Inspiron 1525 Notebook
Dehumidifier has shut down
The GFCI outlet needed to be reset. There was no problem with the dehumidifier itself.
Aug 01, 2009 | Friedrich D40C Dehumidifier
Tring to run restore disk but laptop kepts shut down
Maybe it's shutting down because it overheating. Check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent. You can also try running your restore disk with the laptop sitting right next to a window A/C unit. Try to position the laptop so it gets maximum exposure to the cold air of the A/C unit.
If you get the laptop working again and you think overheating is a problem I recommend downloading a free piece of software named FanSpeed. Here's a link.
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
Jun 02, 2009 | Acer Aspire 5100 Notebook
Cozy hi-efficent wall furnace HEDV403
what you are doing is reseting the heater when you unplug it there should be a overheatswitch that is cutting in and shutting it down
Jan 11, 2009 | Cozy (W352E) Heater
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
