Question about Mrc Ah800 Twin Power Box
Dont no how to wire it for lights for a train set
Lionel train model 2032 engine light doesn't work
If the lamp is good, trace the wiring back to the source to find out why power is lost.
Dec 18, 2016 | Crafts & Hobbies
My son got this train set couple years ago but open it now. Everything is working but it won't move. When he turn it forward or reverse it turn off. Is there anything I can do???
electric trains that sit for a few years require cleaning (yeah I know how'd it get dirty in the box ) but its not the same kind of dirt u/I see its a type of oxidation called corrosion , and it affects the metal parts of set , IE: tracks , wire connectors, engine power pick-ups on bottom of engine they ALL get this light powdery stuff on them this "stuff" will not pass power over to engine and it will not run , this powder can be easy removed with a light rub of 3M scotchbright pad , I don't recommend using steel wool , but I have in a pinch before and 4 sure don't use brillo as this has soap in it (worse than powder)
Feb 21, 2016 | Lionel The Polar Express Train Set
I have a tyco ho scale silver streak train set and do not know how the wires connect from the transformer to the track. theres one side for accessories and the other for train
the transformer shave a knob that makes the train go and go faster as you turn it
some have the knob in a central position so that one way is forward and faster or the other way is reverse and faster
accessories is for boom gates , lights , anything else that you have set up to operate besides the train
Aug 05, 2017 | Chattanooga Bachmann HO Scale Train Set
My transformer on my new polar express does not work what am i doing wrong
No power to the transformer or to the track?
If not to the track, make sure you have the correct wire connections made from the transformer to track.
If no power to the transformer from the wall plug,
sounds like the cord needs replacement.
Dec 19, 2012 | Lionel The Polar Express Train Set
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Jul 05, 2012 | Lionel The Polar Express Train Set
Take wheels off polar express
You will have to solder them using a pencil soldering iron.
Feb 13, 2012 | Lionel The Polar Express Train Set
I have a lionel legacy cab-2 remote i hooked up every thing to the manual but when i turn it on i dont get any track power
just unplug the transformer from the grey box (the one with the green light and red light) and check the voltage. if it doesn't read anything, try unplugging the transformer from the outlet and plugging it back in again. if you get a reading, replug the transformer to the grey box and check the voltage of the silver screws (where you put the + and - wires from the track to) and try using the train again
May 30, 2010 | Lionel 14295 990 LEGACY Command Set V2
How do i wire the transformer? there are four
ther will be four wires but they will ahve all colours
blue black negative red brown for posityve green yellow earth and white may be anothe r earth
any way try and see the colour on the tracks and join appropriate and each wires to them
maybe white and yellow can be joined together
it will not arise any problems by doing so
Sep 27, 2009 | Lionel Trains Classic Freight Train Set
Lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Dec 17, 2008 | Lionel New Haven Freight Train Set
Mrc Ah800 Twin Power Box Logo
19 people viewed this question
Top MRC Toys Experts
Andrew Taylor
Andrew Taylor
Are you a MRC Toy Expert? Answer questions, earn points and help others
