Question about Zebra Computers & Internet
Ls2208 disable beep
  • Official Brand Answer
  • 3,100 Answers
Contact Zebra.
Support Downloads
Mark
Motorola Support
Posted on Jan 10, 2015
My ls2208 scanner is intermittent
If the scanner decodes a barcode one time, but not another the first thing to check is the cable. If the scanner issues the power up beeps when the cable is wiggled, replace the cable. If you know the cable is not the issue send the scanner in to Motorola Solutions (call 800-653-5350) for repair. The LS2208 has a five year warranty. You can roughly estimate your warranty by looking at the date of manufacture on the label of the scanner which is just above the trigger.
Jul 16, 2014 | Symbol Computers & Internet
Scanner 'beeps' etc, but no output on the screen!?
there are a SDK you can try it, confirm that the you had installed the drive.
May 06, 2014 | Symbol LS2208 Handheld
Disable Sleep Mode
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Mar 18, 2013 | Symbol LS2208
Trying to disable intellistand beam turn on when LS2208 is placed in stand.
"Hello, Raschult. We have found a solution for your problem. Simply go to Shift into blue help link and go to page 3. You will see the configuration barcodes to enable and disable "Intellistand Mode". Just print out this page and scan the "Disable Intellistand Mode" barcode. That should do it. If not, let us know and we can try something else. Good luck!"
Dec 30, 2009 | Symbol LS2208-7AZK0100S Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Apr 14, 2009 | Symbol LS2208-7AZK0100S Handheld
Any way to lower the beep sound ...
this are all barcode to solve u r problem.......
please tell me how to set prefix /suffix values ?
i have already set scan prefix & scan sufix and then scan option ...
but did not get the< prfix ><data>< suffix> only data will retrive...
prfix value is `key, suffix value is Tab !
please help me
Feb 04, 2009 | Symbol LS2208 Handheld
I have a ls2208 symbol scanner that need to scan code 39.... The example below is return when I scan the following information. It seems to be do stange thing with the first 2 charecters. Can you help?...
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
Jan 10, 2009 | Symbol LS2208 Handheld
LS2208
Symbol has confirmed that there was a batch of scanners sent out with defective lasers. Call them at 800-653-5350 for a replacement. Have the scanner handy to give them the serial number. They were very helpful.
Oct 06, 2008 | Symbol LS2208 Handheld
Computers & Internet Logo
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
