Question about Lexmark X 264dn - multifunction Laser Printer
Lexmark 200.13 error
Paper will not advance all the way out of the paper tray
How to resolve constant jam error 241 on Lexmark x652de MFC printer?
Double check to make sure roller shaft isn't 'locked' in both directions or spinning in both directions. If the shaft moved to the right a bit, it might be spinning in both directions. If it is, Grab the pick arm in one hand and push the roller shaft a little to the left. The shaft should spin in one direction but not the other. I am a Lexmark tech and have had this happen quite a bit on the 64X and 65X models.
Mar 07, 2017 | Lexmark X652de Multifunction Laser Duplex...
Lexmark T640 printer will not print- get message- media tray empty
Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
Aug 02, 2012 | Lexmark T640 Laser Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Why Error message Tray1 Load LTR
Check the paper settings, tray is set to letter. Tray 1 is running our of paper, check paper guides and properly load paper on tray.
Sep 13, 2011 | Lexmark C500n Laser Printer
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Lexmark X 264dn - multifunction   Laser Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
