Question about Saeco Odea Go
WHEN WE PUSH THE BREW BUTTON ON THE SAECO VENUS COFFEE MAKER IT JUST SHUTS OFF AFTER A FEW SECONDS
SHUTS OFF AFTER PUSHING BREW BUTTON
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 48 Answers
The machine shut down usually when ther is a problem with the load to the grup moter.This is usually a board problem.You can check if the machine shut down when the grup is trying to move.
Posted on May 03, 2014
  • 1089 Answers
SOURCE: Our Saeco Delux Magic coffee maker will not grind
Hi
The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Posted on May 21, 2009
  • 1089 Answers
SOURCE: No steam on saeco aroma redesign
Hi
That is probably you steam thermostat. Its a 127c thermostat.
Posted on Oct 28, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
  • 1089 Answers
SOURCE: Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Posted on Jan 10, 2010
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
The sensor inside the water container has either mineral build-up (scale) or a bit of coffee grounds stuck to it.
  1. Run a cycle with a retail coffee maker "cleaner solution" to clean the water reservoir, or let vinegar soak inside 5+ hrs.
  2. In both cases, turn unit upside down and power wash reservoir 2X to dislodge deposits that have loosened during the soak.
  3. Make sure to run a few cycles of plain water thru coffee maker before making the next batch of coffee.
Dec 06, 2015 | Saeco ODEA Coffee Makers & Espresso...
My Mr Coffee beeps three times when I push the brew button and will not brew
If the carafe, the filter basket, or the water reservoir are not all properly seated, the unit will beep 3 times to let you know it cannot brew until everything is in place.
This happens to me sometimes when I push the button right as I'm putting the carafe in place. I just need to wait a few seconds.
Oct 03, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
The brewer unit light seems to stay on and the coffee maker wont respond when pressing the coffee dispense buttons
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, (use a food grade lubricant) so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Aug 13, 2011 | Saeco Magic De Luxe Espresso Machine
The brewing unit doesn't click in anymore, seems to not be aligned anymore
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Jul 04, 2010 | Saeco Stratos Coffee Maker, Espresso...
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
My Incanto Sirius coffee maker is acting strange. It automatically keeps brewing (1) large coffee. The only way to stop this is to shut off the machine. I am getting a LCD read out of Program quantity....
Program quantity is trying to program that amount.
When it starts to brew and gets to the quantity you want for that cup size push the brew button again and see if it stops.
Nov 21, 2009 | Saeco Incanto Sirius Fully Automatic...
Shot is too short
Hi
You can program each coffee button by pushing and holding the particular button. Do not release the button until it has gon through the grind and then brew process. When it has gotten to the amount of coffee in the cup that you would like for that button, then you can release the button. It will do the same amount the next time you push that button. When you are programing buttons, you will see in the display "Programing coffee" If you push one of the buttons for more than 5 seconds it will go back to zero and you will get no coffee for that button and have to reprogram that button..
Oct 14, 2009 | Saeco Royal Professional Espresso Machine
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
91 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
