Question about Symbol Computers & Internet
How do I configure my dt3100 to read interleaved 2 of 5 that is 12 digits long?
  • Official Brand Answer
  • 3,100 Answers
Hello
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads for assistance.
Mark
Motorola Mobility Support
Posted on Jan 20, 2015
2 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: Cannot read symbologie/BarCode: i25(interleaved 2
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Posted on Mar 26, 2009
I have 2006 freightliner what is the code n 2,12
Greetings
"Great choice of service Repair and Manuals"Large pictures deals or discounts is there.You buy in less amount so please use it
May 26, 2016 | Cars & Trucks
Tip
Set VirtualDubMod to Align Audio Frames across Interleaves for better sync
The default for the this program is Enable audio/video Interleaving with a 500ms pre-load in VirtualDubMod,this is the recommended value, it is not an offset this is done in the Audio Skew Correction the same is true for its older cousin VirtualDub.
This will set the Audio Frames to "Split across interleaves" which can cause the audio to go out of sync with the video even if the MP3 is set to CBR a problem most known with VBR audio on standalone DVD players that that DivX capabilities. This is one reason why the preferences are set to warn you about VBR audio this is a screendump from VirtualDub
It is said that if the AVI has Audio frames that are "Aligned on interleaves" it will always remain in sync even with a VBR MP3 audio track.
If you experience VBR MP3 problems you can turn off the MP3 ACM and use VirtualDubMod MP3 encoder under here the default preload for AVI audio is set to 500ms as shown this is the same in VirtualDub.
If you are going to re-encode the MP3 audio to AC3 the audio gets split across interleaves with the default values MP3 seems to Align with Interleaves itself .
However if you Enable Frame Mode the resulting AC3 will get "Aligned Across Interleaves" (you can't do this tweak in VirtualDub by Avery Lee)
Options -> Preferences -> VDubMod -> AVI -> Enable Frame mode.
If you are OK with this then you can re-encode the VBR audio MP3 to CBR dolby digital AC3 audio "Aligned Across Interleaves" and know that your audio frames will be aligned with the Interleaves and AV sync problems on your DivX enabled DVD players.are over.
on Feb 10, 2010 | Philips DivX DVD Player
Remove last digit on a it3800
You should try downloading the configuration manual from Honeywellaidc, it should probably be there still.
When you have the setup book, search for data transmision options.
Apr 14, 2014 | HHP IT3800 Handheld
MEMORY CONFIGURATION error: bank interleave reqested but not enabled
Sorry but that doesn't make much sense. If the correct RAM is fitted, there will be no issue. If you are using two chips and they are a different batch, maybe one is interleaved and the other not.
Feb 12, 2014 | Acer Aspire 3100-1405 Notebook
Is it a good idea to remove interleaving?
Simply put - no.
Interleaving is a way that the technology can "auto correct" or "auto detect" errors that occur. While interleaving may increase latency, errors that it can catch outweigh the result of removing interleaving.
Nov 12, 2011 | Gateway Computers & Internet
Error 207, invalid memory card configuration
The Memory were installed in an incorrect order. The Memory must be interleaved for the server to work, Follow instruction on the cover of the server.
Jul 15, 2011 | HP Compaq ProLiant ML530 Server
We are using Unitech PT630, HT630 for our stock audit at various retail outlets. we get wrong barcodes while scanning. Most of the times, scanner return only 4-6 charectors or part of the barcode is read...
Algunas simbologias de codigos de barras pueden dar lecturas parciales (como el interleaved 2 de 5). Entonces verifica lo siguiente: el lector laser este limpio, y en la aplicacion puedes restringir la lectura a un numero fijo (8 por ejemplo) para que solo lea codigos de barras de longitud fija. Some bar code symbologies can be read in part (such as Interleaved 2 of 5). Then check the following: the laser reader is clean, and the application can restrict the reading to a fixed number (8 for example) only to read barcodes of fixed length.
May 12, 2009 | Unitech 630D PDT 2.5MBRAM LR CCD SCA
C coding
  1. Read the file A o/p-> aaaaaaabbbbbbb………..ppppppp
  1. Read the file B o/p -> 11111112222222…………00000001111111
2. The o/p of the file c based on the outputs of the files a & b. The output of the file C
should be like using interleaving techniques.
aaaaaa1111111bbbbbbb22222222………….
3. The output of the file D should be the o/ps of the above 3 files
    aaaaaa1111111aaaaaa111111…………..bbbbbb222222222bbbbbbbb2222222……………..
    Develop the program using pseudo code.
    6. Show the o/p of the file C which must based on the file A & B
Mar 22, 2009 | Computers & Internet
Have a hp DC7100 minitower pc with 4 dimms slots currently have 2 512's installed and thougth maybe adding an additional 2gig dim basically filling 3 of the dimm slots is this configuration valid
■The system will operate in single channel mode if the DIMM sockets are populated in one channel only.
■The system will operate in dual channel Asymmetric mode if the total memory capacity of the DIMMs in Channel A is not equal to the total memory capacity of the DIMMs in Channel B.
■The system will operate in a higher-performing dual channel Interleaved mode if the total memory capacity of the DIMMs in Channel A is equal to the total memory capacity of the DIMMs in Channel B. However, the technology and device width can vary between the channels, For example, if Channel A is populated with two 256 MB DIMMS and Channel B is populated with one 512 MB DIMM, the system will operate in Interleaved mode.
Oct 15, 2008 | HP Computers & Internet
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
35 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
