Question about Frigidaire PLMV169DC Microwave Oven
Fridgidare model FGMV153CLB - Frigidaire PLMV169DC Microwave Oven
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
What are matching models for Whirlpool Oven door model AKZ456/IX
As You may know, Whirlpool also builds Kenmore products, that being said, You would be far better off buying the exact model door for Your oven. The joy You may get from saving a "C" note on an alternative door option could turn into a Personal B*tt Kicking contest when You discover it almost worked, You CAN'T send it back and You still have to buy the right one. Best of Luck to You.
Aug 19, 2014 | Microwave Ovens
Need to find a manual for bread machine , brand name: Wel Bilt. model number:ABM1H70
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the word MANUAL + the abbreviation PDF to perform an Internet search. Google is best for these types of searches.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would want to enter your search as:
FREDERICKS HOME BAKERY KHB178 MANUAL PDF
Hope this helps & Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 23, 2011 | Microwave Ovens
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
I"m looking for a wiring
The closet model number I could find was the BT83Al which is a discontinued model. At teh follwoing site you can download a User Manual and Technical Drawing.
http://www.baumatic.co.uk/bt83al_21_106_550.html
If this is not your model other discontinued models can be found here:
http://www.baumatic.co.uk/cooker_hoods_21_106.html
Current Models:
http://www.baumatic.co.uk/cookerhoods.html
Feb 11, 2011 | Baumatic Microwave Ovens
Have model jvm1740sm1ss ...keypad has shorted ...cant seem to find parts for this model even on ge site
This should be the correct parts listing for the model number you have provided:
http://www.pcappliancerepair.com/model.php?mn=JVM1740SMSS01&man=&mid=&brand=GEH&pmid=0
Here is another part listing which is a slight variation of your model. The part numbers are still the same, however:
http://www.pcappliancerepair.com/model.php?mn=JVM1740SM2SS&man=&mid=&brand=GEH&pmid=0
I believe the model number should read "JVM1740SMSS01". If you have any questions, please post back and let me know. I hope this helps you.
If these links do not work, go to pcappliancerepair.com.
Here's another listing available at appliancepartspros.com:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218277
Here's another listing available at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JVM1740SMSS01/0432/0123370?searchedModel=jvm1740sm&blt=
Oct 28, 2010 | GE Microwave Ovens
THIS MODEL JUST WENT OUT, WHAT WOULD BE THE NEW REPLACEMENT MODEL
Please reply back with your brand and model number so we can help you.------------------------------------------------------------------------------------------------------------------------ Please reply back with your brand and model number so we can help you.
Aug 19, 2009 | GE Microwave Ovens
Which brand microwave oven is best in the market
That kind of depends what you want. Kenmore, Whirlpool and Fridgidare are the best value. Maytag, Amana, Jenn Aire are a little higher end. LG and Electrolux are the higher end. When it comes down to it most of them have some of the same components. Keep it simple. The more bells and whistles, the more likely it won't last. Sometimes the cheapest ones are the best. Personally, I have a countertop unit by Emerson. 10 yrs old, no problems.
Mar 25, 2009 | Samsung 80092 Microwave Oven
Model no. correct??
It doesn't look like a valid Magic Chef model number.
The word "model" will appear beside it on the model / serial tag on the unit.
Also, you can check this page for recent Magic Chef models.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 07, 2008 | Microwave Ovens
Frigidaire PLMV169DC Microwave Oven Logo
27 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
