Question about Frigidaire FPHB2899PF Professional 27.8 Cu. Ft. French Door Refrigerat
How do you take the control panel off of a fphb2899pf fridge to replace
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
My american fridge freezers alarm has just gone off and the temperature is reading -- and flashing
is it a side by side if so it is more likely your rear brd that has failed and needs replacing. This brd controls the appliance.It is located in the rear behind the panel at the bottom. Looking from behind it is in the bottom right hand corner
Mar 26, 2010 | Whirlpool Freezers
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
Freezer won't freeze
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 08, 2009 | Frigidaire Freezers
Freezer blowing cool air, but not freezing.
Hello there:
first make sure that the back of the unit is clear of any dirt or obstructions
also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a Maytag MSD2142ARW side by side and it has been steadily gettingwarmer on the fridge side. The freezer appears to be cooling fine and I know the fridge gets its cool from the freezer side. The fan...
HI, your Temperature Control Module has failed. it controls the air flow and vent(damper) action. replacing the temp control mod will fix this issue you are having at this time.
Jun 10, 2009 | Maytag Freezers
The Fridge stays too cold at -6.
Yes it is the thermostat. Replace it or have it replaced.
Jun 13, 2008 | Freezers
Frigidaire FPHB2899PF Professional 27.8 Cu. Ft. French Door Refrigerat Logo
65 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
