Question about Saws
Jobmate reciprocating saw parts 5481506
Where can I get a set screw for holding the blade for my job mate reciprocating saw?
rowdy45176
  • 2176 Answers
SOURCE: Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Posted on Mar 22, 2009
joboo1
  • 257 Answers
SOURCE: I need instructions on removing the front housing
Hi again Guy, It is easy to overlook the obvious, I do it a lot. There are two allen screws in the rubber boot at the front bottom that need to be removed to release the foot (or shoe), which should slide out the end. Then the whole boot ( forward hand grip) pulls off the end exposing the assembly you need to replace. Good Luck to you, this should Fixya!
Posted on Mar 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
Posted on May 26, 2009
SOURCE: Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Posted on Jul 22, 2009
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
Saw blade jammed - cannot remove
Unplug from power. Spray blade locking mechanism with wd40 or similar lube. 1. If you have a quik release, work the release with a pair of channel locks while wriggling the blade. If not removed, you can remove the footplate from the saw and drive the pin out that holds the quik release in place, paying attention to how the parts reassemble. 2. If you have a set screw retainer, totally remove the retainer.
Sep 08, 2012 | Milwaukee Tool 10 Amp Sawzall Plus with...
We have a ryobi rj150v model reciprocating saw (older model) which needs the blade replaced. It had a broken part, which I ordered several years ago. My husband's FINALLY going to replace the blade,...
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Ryobi Saws
I need directions on how to change the baldes on a reciprocating saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Have DeWalt Model 303 Type 1 Blade is stuck can not remove, removed Scew part # 99164-06. Blade is still stuck, blade will move side to side, back and forth but will not slide out. Any ideas
It sounds like the set-screw may have caused a burr on the blade, and that's preventing you from removing it. You might use a tool like vice-grips, and apply more force. I don't think you can hurt anything by doing that if the blade is in the fully-extended position.
Good luck,
genetuck
Feb 13, 2011 | Dewalt 15 6" Reciprocating Sawzall Saw...
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Mar 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Locking screw for blade on reciprocating saw
Virtually every manufacturer has a different size thread for the locking (set) screw on their saw. Your best bet is to contact the manufacturer for a replacement.
Feb 11, 2010 | Garden
How do I disassemble a craftsman 10 amp reciprocating saw?
To remove the front half of the saw:
1. Remove the two screws that hold the guide shoe
2. Pull and wiggle the guide shoe straight forward and out.
3. Remove the metal support from the front of the rubber boot by prying it out of the groove.
4. Using a pick or a very small screwdriver, pry the retaining pin from the blade release handle and remove from the front. It removes without much friction.
5. Remove the blade release handle through the side of the saw by wiggling and releasing the return spring.
6. Remove the rubber boot off the front of the saw by gently prying near the center of the saw and firmly pulling.
7. Remove the six screws to remove the black plastic dust cover.
8. Remove the remaining two screws and lift the grease guard to access the reciprocating mechanism, being careful not to drop the needle-bearings. This area can be packed with grease.
The handle part of the saw is self explanatory.
Dec 26, 2009 | Saws
Saws Logo
37 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
