Question about Soundstream lw4.500 lw4500 lil wonder iii generation lw3g
Lw3g hi i have a lw3g. in one chanel it has noise like wind sound what can i do?
Hi my onkyo ht-s3500 no sound all chanel only noise after l reset what can i do solve this
Hi
SEARCH ENGINES ARE YOUR FRIEND. You can bet you're not the only person in the world with this problem - just search for the model number and problem.
R
Apr 26, 2016 | Onkyo Audio Players & Recorders
Program chanel memory
Try an auto tune process to get all channels in sequence. Refer to its user manual for details.
Apr 22, 2012 | Televison & Video
Wind noise at about 60 miles a hour
This is common with these cars. There is no fix for the wind noise.
Oct 15, 2009 | 2000 Ford Crown Victoria
The sound recording is noisy
try setting the options on the sound recording lower and try to find the wind audio correction selection. that should work.
~good luck
Jul 14, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
No sound on tv chanel
hi, no sound with tv but have picture, also have lost sky but works on other tv with a tv link, tv make LG Lh3000
Apr 22, 2009 | Logitech Harmony One Advanced Universal...
Samsung ps42d5s-screen is blacked out
Heya,
Does anyone know where i could get a LVDs cable for a samsung 42 inch tv searched everywhere and cant find one the model number is PS42D5s thanks in advance
Feb 27, 2009 | Samsung PS42D5S 42 in. EDTV-Ready Plasma...
Winding noise
Is this noise coming from the rear of the vehicle, if so it "sounds" like a rear pinion bearing concern, this would make a winding noise when under a load(accelerating) and disappear at other times. Keep me posted
Jan 08, 2009 | 1998 Toyota 4Runner
Wind noise on vhs
Hi Claire
Wind noise is very common when recording outside.
Firstly, make sure the microphone you use is uni-directional. This means it will work in the same way that a television antenna does, in that it will pick up sound from the direction it points in, but sounds from other directions will be attenuated. These mics are often used by broadcasters and those in noisy situations, football matches etc.
Secondly, make sure your microphone is fitted with a good foam wind cover. If it already has one, fit a thicker one. This is the single most important thing you can do to cut down on wind noise. You can always get yourself some foam and wrap it around the microphone, right over the top, and tie it with a piece of string.
It sounds a bit wacky, but even pro broadcasters do this from time to time.
Finally, consider using an extension mic cable and positioning it closer to the signal source. Be careful though. If the neighbours are that bad, make sure you are not on your own.
Good luck and best wishes
Helen
Apr 04, 2008 | Televison & Video
Great pic but bad sound
Your problem could be the main amp board, the signal panel or the audio processor board. You will need to get a service manual for this set to diagnoise these problems. Good Luck
Mar 31, 2007 | RCA D56W20 56" Rear Projection Television
Soundstream lw4.500 lw4500 lil wonder iii generation lw3g Logo
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
