Question about Samsung Prostar 816 Phone
Restricted line prostar - Samsung Prostar 816 Phone
How to upgrade samsung prostar 8/16
sorry but only your phone company can do that .
Oct 28, 2015 | Samsung Office Equipment & Supplies
Can't make an outside call, phone says "restricted
contact to your service provider for lift restricts from calls
good luck
Mar 02, 2011 | Samsung Prostar 816 Phone
Trying to make a conference call from the conf speaker (using the flash button) calling two outside lines.
Once you start using the Conference key on the Prostar 816 you will find it really easy to use, and very helpful! I have uploaded a training video for you to watch, other prostar 816 clips are available on Youtube searching for abbeytel. Visit www.abbeytelcom.com for written copies.
Nov 22, 2010 | Samsung Prostar 816 Phone
My Prostar 816 will not ring. The lines will light up and flash when there is an incoming call, but I have no ringing sound. How do I get my telephone to "ring"? Thank you!
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Sep 01, 2010 | Samsung Prostar 816 Phone
Phone lines on Prostar DCS are locked up.
That is common, the company that originally set it up, or someone who serviced it at some point changed the default password. you need to call a technician to come out and service it, this will require opening the system up and clearing the memory, then it will have to be reprogrammed.
Mar 24, 2010 | Samsung Prostar DCS Phone
How do I program prostar 816 to ring?
with the handset down enter #20 the screen should say MMC DISABLED
Mar 09, 2010 | Samsung Prostar 816 Phone
How do hook up a caller ID box to a Prostar 816+.
Unfortunately, The prostar system was not compatible with CLID. The next best thing you can do is to have the telephone line(s) that have CLID extended to where the phone is located and plug in your box(es) directly into the telco line.
Dec 17, 2009 | Samsung Prostar 816 Phone
How do I turn off ringer for fax line on prostar 816?
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line button for the fax line
4) press the button for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
Jul 16, 2009 | Samsung Prostar 816 Phone
Prostar 816 need to turn ringer on
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
hope that helps
Jan 30, 2009 | Samsung Prostar 816 Phone
Prostar 816 Toll Restriction
The Station Toll Class of the phone needs to be changed to a Toll Class 5 which allows 911 calls and certain numbers set in MMC # 94. The program to do this is MMC # 30. The problem is when MMC # 30 is accessed it displays the Toll Class for all 16 phones so use caution that you do not change the wrong extension. If you still need help with this problem please repost and I can walk you thru the process.
Apr 25, 2008 | Samsung Prostar 816 Phone
Lands Phones Logo
10 people viewed this question
Top Samsung Lands Phones Experts
richie46
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
