Question about John Deere Tractor Turbo Charger 6200 6200l 6300 6300l ()
JD 6200 pto no power under load
Dose turn when no hooked to equipment
  • 58 Answers
SOURCE: I have a JD 1070 4 wh dr, when running a brush hog
Reading on line, I see your tractor has a PTO clutch. It must be slipping. It either needs adjusted or replaced. A slipping clutch disc will make a bad smell.
Posted on Jul 28, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
  • 203 Answers
SOURCE: JD 420 PTO works fine when cold/newly started.
I used a neighbors 420 while mowing and there were times that I tried to restart the blades after turning them off for a bit. I found, I think, that you had to have the brake depressed to make them turn back on.
Posted on Oct 23, 2009
wireguy212
  • 1627 Answers
SOURCE: jd 3020 power shift pto turns all the time. if
The pto brake is either worn out or you have no presure to it when the pto is turned off,most likely the pto brake is worn out.
Posted on Nov 24, 2009
wireguy212
  • 1627 Answers
SOURCE: Ever hear of a PTO running in reverse? I have my
Is your blower running off of a belt or a pto shaft?If it is running off of a belt then you likely have a twist in the belt that shouldn't be there ,have a look at it to see if it crosses it's self somewhere.If it has a shaft then the drop box needs to come off and the gear arrangement checked out.
Posted on Jan 08, 2010
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
JD ltr180 stalls when blades engaged
if it has an electric pto for the blades, it is possible that by engaging that pto, there is not sufficient power left to run the engine
check charge rate , battery condition and pto system
Jun 30, 2016 | Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
Why does the pto on my not turn on?
Electric clutch may not be getting enough power. Check fuse. It may be getting power that is not sufficent from low battery. Check water level in battery, check power by turning lights on and cranking motor. If lights go very low then battery is suspect. If my JD battery gets very low it has to be charged with external charger as the JD charger cannot bring very low battery up and drive clutch too.
Jul 21, 2014 | John Deere Garden
My JD 140 discharges when I turn the PTO and/or my lights. Does my starter also charge my battery?
If your battery is old or low then it may not have the power to run the PTO. It also depend on the size of the object that you are trying to operate off of the PTO shaft and if your engine can take it. Only the rear PTO is live or uses generated electricity. The front one is independent so it probably runs off the battery.
Dec 30, 2012 | Garden
While cutting grass the pto clutch cuts off, i have to push switch in and back out to restart blades. I have replaced the switch and pto clutch
Check operator present switch under seat. Perhaps you'r moveing and not staying on switch. Check wires to pto, and seat switch.
Aug 18, 2010 | Oregon Scientific Electric PTO Clutch for...
Jd 3020 power shift pto turns all the time. if lever not engaged a heavy load can stop it. otherwise it works ok
Nov 03, 2009 | John Deere 3010,3020 Tractor Basic...
I have a JD 1070 4 wh dr, when running a brush hog on the back pto, what would make the pto shaft slow down under a load when cutting light brush, funny smell. Checked all oil levels.
Jul 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Tractor Turbo Charger 6200 6200l 6300 6300l () Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
