Question about Acer Aspire Computers & Internet
Acer aspire 5750 won't turn on
Won't turn on - blue light comes on for a few seconds then turns off again and the laptop will not boot. I have taken out the battery and drained the power to no avail.
    Top Expert:
  • Acer Master
  • 8,213 Answers
Check you fan make sure its running,,some times if its not it wont let the laptop start.
Posted on Apr 05, 2015
  • 7 Answers
SOURCE: Acer Aspire One hangs during boot and then powers off after 30sec
sounds to me like you need to restore your bios settings to default. if you can get into bios usually by pressing delete then it shouldnt be too hard. if that dont work the next easiest thing to do is to take out the battery that is inside the laptop somewhere on the motherboard! this will clear bios settings after about 2 or 3 mins of being out make sure the computer has no other power going to it when you take out battery
Posted on Feb 17, 2009
  • 38 Answers
SOURCE: Sony Vaio VGN-N250E/W Not Booting/Responding
Take the battery and power supply out and hold down the power button for 30 seconds. This will reset your hardware settings. Your backup battery isnt your problem. Does your battery light turn on when charging? Does your keyboard lights light up when it runs for a second (try pressing caps lock)?
Posted on Mar 25, 2009
  • 16 Answers
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Posted on Aug 23, 2009
Testimonial: "Exactlt what I had been thinking!"
  • 1481 Answers
SOURCE: acer aspire 5520 endless rebooting problem!!!
the registry is corrupt...this happesn after frequent use and windows files getting corrupt...
get Tuneup Utility and crack from my website and install both the software and crack then clean the registry using the tools in there...
go to Download page in
www.sureshayyar.110mb.com
Posted on Dec 26, 2009
  • 177 Answers
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Posted on Mar 07, 2010
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
I have a acer aspire 5920 the amber light comes on but when I try to turn the computer in the blue light lights up then goes off and will not turn on! Pls how can I fix this??
One suggestion I could offer is to unplug the laptop and remove the battery, then proceed to hold the power button for 20 seconds and then attempt to boot the laptop again.
Sep 17, 2013 | Computers & Internet
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
Power light comes on,but no video,fan runs for a few seconds then turns off does not boot,what's up?
First, remove the battery and unplug the ac adapter then press and hold down the power button for 10 seconds to drain power from the laptop. Remove any external usb device or flash cards inserted in the computer.
Set aside the battery for the meantime and connect the ac adapter. Now turn the laptop on and see if it powers up. If it powers up, then you resolved the issue but if it doesn't, then you might have an LCD or Motherboard failure
Jun 23, 2010 | Toshiba Satellite A135-S2276 Notebook
Computer comes on and I only get blue screen. Taken battery out, turned electric plug off. Hit start button 30 seconds, then plugged up electricity, started machine, still nothing happens. What other...
Another suggestion is to take the power out, remove cables and battery then press and hold the power button for 10 seconds. Then reinsert the cables and battery and turn on the pc. If the blue screen still appears, take note of the blue screen error and try to boot to safe mode with networking. If you have a recovery disc, boot it by pressing F12 repeatedly in startup to run the check disk. If did not work, then you have no choice but to reinstall the operating system...
Jun 19, 2010 | HP Pavilion tx1000z Notebook
My Dell 1501 laptop turns off as soon as the charger is connected
Sounds like you have a multiple problem going on here honestly. If you have a constant light on your charger even when its completely disconnected from the wall outlet then your charger is bad for sure, cause the light shouldn't come on unless the charger is hooked up to power.
Your battery maybe shorting out the laptop which is why it needs to be taken out for a bit before the laptop will turn on.
My suggestion would be to try a known good working charger on your laptop to make sure it turns on properly and stays on without the battery hooked up.
Then if your laptop stays on for a while then with the laptop on and the charger hooked up, connect the battery again and see if the laptop will charge up the battery to 100%. If it does then disconnect the charger and see if the laptop stays on with just the battery hooked up. It could be that the battery is drained beyond 0% and just needs a good charging. If you can't charge up the battery or the laptop still turns off to where you have to take out the battery to get the laptop to turn on then the battery is bad and would have to be replaced.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
