SOURCE: Print the date on the image/photo
It is not possible to embed the date/time stamp as part of the image itself with the XT. The date/time information is stored as part of the exif information stored in the image at the time of shooting.
However, you do have a couple options for printing images with the date/time stamped onto the image:
If you use the direct print capabilities of the camera when connected to a compatible printer (PictBridge, CP, or DirectPrint are all supported), you are able to enable an option that will print the image with the date/stamp printed on the image. There are also software packages that you can use that will do the same when printing from the computer.
And finally, it is possible, with some photo finishers, to request that they imprint the shooting date/time on the image. This will vary from photo finisher to photo finisher, and the will be some who can't, or won't, do this.
SOURCE: date/time issue on Canon EOS 350D
I was wondering the same when I first got my EOS. Learned later that the digital pictures do not have date/time stamp on the front of the photos like film cameras' photos. Details of digital photos are stored digitally in each image file's EXIF.
If you want to print photos showing the date/time, some software including Zoombrowser EX can do that. In Zoombrowser, select the photos you want to print. In Step 2 (Printer & Layout Settings), in the bottom left, you can choose Date and/or Time and even the colour of the font.
SOURCE: how to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The
date will be printed on your images even if it has not been set at the
computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
SOURCE: how do i turn on the date stamp on my Canon Powershot SD750
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
