Question about Frigidaire FFBD2411NB 24" Built-In Dishwasher in Black FFBD2411NB
Wont start, circuit breaker ok - Frigidaire FFBD2411NB 24" Built-In Dishwasher in Black FFBD2411NB
Circuit breaker trips out
What is the rating of the breaker? Is this enough to run the saw? If this is ok, has the motor become damaged or has the blade got dirt or wood dust slowing it down?
Jul 25, 2014 | Hitachi C10FR 10" Job-Site Table Saw 15...
Where is the fuse for trunk
The trunk pull-down circuit is protected by 30A circuit breaker 24 in the fuse block. If the circuit breaker is OK, power is applied through 20A FUSE 4 in the relay center to the pull-down unit.
Jun 11, 2014 | 1990 Buick Electra
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
Started then stop and wont come back on. circuit breakers checked, all wiring checked, door closed. light on inside on, could the start stop switch be defective?? dryer is about 10 years old. DRYER...
yes could be start /stop microswitch...firstly make sure fuse ok in plug also feed ok lastly ensure post to operate door switch has not broken off........hope this lot helps.....
Jan 14, 2011 | Dryers
Machien wont start, fill up or anything please help
just had same problem, washer was working and when new load was started it would not start. circuit breaker popped and reset it. no lights on panel and circuit breaker good in house. pulled power panel off and opened circuit card and notice black burn spots between cards which looks like the control panel is fried now. Cost about 200 to order, not knowing other costs if repairman fixes it.
Oct 02, 2010 | Washing Machines
Is bryant breakers ok in a murray box
Look on the label inside the door on the circuit breaker panel. It should list part numbers for acceptable breaker. The key is the part number. Bryant is now owned by Westinghouse. Murry is now owned by Siemens. While many breakers will fit in other brand panels, they are only code compliant if they are listed for that panel in which they are installed. Since names have changed go by the breaker numbers. If the breaker number you have is listed on the label then it would be ok. Breakers aren't that expensive, if you have doubt, go to your supply house that carries Siemens and buy breakers listed for your panel.
Jul 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Feb 08, 2010 | Electrical Supplies
Maytag PYE2300AYW Dryer wont start or run. I replaced both thermal switches still nothing. What next?
Check the dryer breaker pair in the house electrical panel. Push off, then on. Try the dryer again. If works, ok. If not, recheck the breakers. If tripped again, the dryer has an internal short circuit--likely in the heating element(s). The drum must be removed to service the element(s).
Aug 28, 2009 | Dryers
Frigidaire FFBD2411NB 24" Built-In Dishwasher in Black FFBD2411NB Logo
15 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
