Question about Maytag Dishwashers
Replace filter dwu7910
Is there a filter under the swing arm and how to remove them
3 Suggested Answers
lenwest
  • 150 Answers
SOURCE: maytag dishwasher model dwu7910, water enters
If the water drains its probably not the pump.The arms can get plugged ie: dryed soap,food excetra can build up.Try using an ice pick or tooth pick and push into each hole,or disassemble and clean.Let me know.
Len
Posted on Feb 22, 2009
  • 949 Answers
SOURCE: want to remove the spray arm and clean the filter
Below is a link showing how to clean out the sump area below the spray arms. If you want to clean the top filter when taking it apart, vinegar works to dissolve a lot of the deposits.
Sump Clean out
Posted on May 31, 2010
How do I remove the race out of my polaris magnum 325 swing arm ? Should I buy a slide hammer?
Do you have access to a press? ... ask around.. or take it to a friend at an automotive shop.. you will save yourself some grief..
Oct 26, 2016 | Polaris 2004 Magnum 330 4X4
How do you take the swing arm off of a 1982 harley davidson
Raise rear tire off ground. Loosen chain adjusters, loosen and remove axle nut and remove axle. Remove chain from rear sprocket. Remove bolt from lower shock mounts. Loosen nut on swing arm and remove swing arm bolt.
Sep 24, 2013 | Harley Davidson Motorcycles
2006 c90 swing arm bearing replacement
how do you remove the swing arm from susuki c90
Aug 06, 2012 | 2006 Suzuki Boulevard C90
Where is the cabin filter located on my 2006 Ford Escape? I use to have a kick *** AC, but lately it needs to be turned up to really work. Someone said that I may need a new cabin filter. Where is this...
The 2006 ord escape has two locations for a cabin air filter, they had a change up year modification
first and most popular location is under passenger side of the wiper cowl: To remove the cowl, you have to first pop the cap on the passenger side wiper arm and remove the nut usually a 13mm nut so you can remove the wiper arm, once arm is off you can remove the screws retiaining the plastic wiper cowl, once cowl is removed you will see air box on the left where usually jam up with leaves or dust etc..replacement is just removing out and placing new one in the place where the old one was
2nd location will be behind the glove box, you need to squeeze the sides of the glove box to allow it to open and swing down. Once glove box down and out of the way you will look directly back and see a cover retained with small 7mm screws, remove them and behind you will find you filter which slides in and out.
Good luck and any more questions feel free to ask
Thanks Jay
Jun 22, 2011 | 2006 Ford Escape
How do I remove and instal the swing arm.
Jack the rear wheel up and remove it from under the bike. Take the rear shocks off. Take the large bolt that holds the swing arm into the frame right behind the transmission. Keep in mind that the large bolt also supports the transmission as well. You must put something under the transmission to support it.
Good Luck
steve
Feb 17, 2011 | 2003 Harley Davidson FLHRCI Road King...
How do i change and drain the motor oil for a 2001 Harley Heritage Springer model?
remove the dip stick(right side of bike) for free flow,drain plug is under rear swing arm bottom of frame, not the one under primary,once drained, remove oil filter in frount of motor(u might need a special iol filter wrench), u will get oil on motor, cover with something. once all drained, fill at dipstick till where it is at full mark on stick(about 3 1/2 qaurts). run bike foe about 10 min., then shut off and recheck, add more if needed.
Aug 05, 2010 | 2001 Harley Davidson FLSTS Heritage...
I need to know how to replace a 2001 soft tail Harley final drive belt. Does the swingarm have to be removed?
yes buddy swing arm removed belt put behind swing n arm and the wheel losened and slide the wheel forward dont force the belt and after 100miles check the belt tension if so adjust it and also you will require a torque wrench to torque the bolts on swing n arm and on rear wheel the wheel is 100 NM and swing n arm is 79 NM bud
Nov 03, 2009 | 2001 Harley Davidson FXSTB Night Train
Removal of swing arm
remove seat and fuel tank/ air filter box assembly.
get the bike off the ground and secure so it wont fallover.
remove rear wheel, release the rear brake hose ,
undo clamps holding shock tank,
remove upper shock mounting bolt,
remove bolt holding double connecting rod to chassis,
remove ring nut and fork pin adjuster,
remove pin,
remove shock double connecting rod from chassis,
undo wishbone shaped brackets both sides , from centre attachment..
swing arm should be free..
Oct 17, 2009 | 2002 Aprilia RS 125
Final drive oil seal replacement
The problem is that the engine, or swing arm should be removed in order to make his job easy . Make sure that the bearing behind the seal doesn't have play side to side . I don't think you could get enought room to slip the new seal over the shaft by removing the final drive unit at the rear wheel, the locking bolt under the rubber boot behind the seal,and sliding the drive shaft assembly back into the swing arm cup . If you have to pull the swing arm off, it would be a good time to re-pack the bearings with moly grease . The old seal just prys out, and the new seal must be tapped in evenly . Do not distort the seal . Try to find something round that fits the seal to tap opon . I have used plastic pipe . J
Jul 29, 2009 | 1982 Honda CX 500 B
Maytag dishwasher model dwu7910, water enters bottom, but does not spray through arms. Water will drain. Bad motor/pump assembly?
Len
Feb 22, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
