WD-40 oil Will WD-40 damage the shredder? I used it once!
  • 3 Answers
WD-40 should not have damaged your shredder if you have used it on metal parts, and though certain plastics can be melted with WD-40, probably hasn't done any damage. However WD-40 is not an oil, nor a lubricant (it is a degreasing solvent). If you want to apply a lubricant, use a light machine oil such as this: amazon.com/dp/B00200B22S. Much better.
Posted on May 09, 2014
    Problem Solver:
  • 6 Answers
WD 40 is penetrating oil, so make sure to only put it on the metal parts of the shredder and not on the electronics. Minimize the overspray oil on the plastic parts also. This will not damage the metal blades.
The normal oil is a light viscosity like 3-in-one oil with no penetrating characteristics (10 weight oil).
2 Suggested Answers
  • 125 Answers
SOURCE: shredder sounds like dry rubbing when in use.
No do not use WD-40.
They make shredder lube. It is a thick silicon type oil. I would just google shredder lube and I'am sure you will find what you need.
Good Luck
Andrew
Posted on Mar 17, 2009
How do you oil this shredder?
You did not give the model ## of your shredder. Most all shredders are OILED from the top slot where you you insert the paper to be shredded. DO NOT USE WD-40 OR ANY OTHER BRAND TYPE OIL. Use oil made for shredders or you can use SILCONE type oil. Wd Corp & Liquid Wrench companies make this type of oil. I have used it for more than 10 years in my shredder and I have not had a problem. The cutters work great.
Make sure BEFORE you oil that you make sure all shredded paper is removed from the cutters.
Spray from one side to the other(paper feeding slot) Run the shredder forward and backwards (WITHOUT PAPER) for about 5 seconds. This should be sufficient.
Sep 02, 2014 | Fellowes Office Equipment & Supplies
Will WD-40 damage my shredder even when used in small quantity?
It should be alright. It's best to use actual lubricant sheets that you can typically get from stores that sell shredders.
Your best bet is to plug it in (being careful at EACH step) and try just a single sheet of regular paper in it.
I would run a few single sheets through, turn it off, unplug it, then see if the top of the pile is still wet from the WD-40. If not, then you should be good for standard use.
Apr 16, 2014 | Fellowes DM12C Shredder
I used WD-40 just once. How can I know if I damaged it completely?
WD-40 probably hasn't killed it, most of it will evaporate in time. It can cause the shredder to get gummed up with little paper particles so you might need to clean it out with some compressed air. I wouldn't use any sprays on a shredder unless Fellowes recommends it.
Jam with a cardboard from check book
On most Fellowes ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 27, 2013 | Fellowes (R) OD1500C High-Performance...
Dq61mn feed
On most shredders ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 25, 2013 | Office Depot Ativa DQ60M Shredder
How can I clear a paper jam on a hsm securio b32 shredder when the reverse function does not clear it
Oct 16, 2013 | HSM SECURIO B32 Shredder
How can I clear a paper jam when the reverse function does not work
Oct 16, 2013 | HSM SECURIO B32 39mm shredder
Cb650v paper cutter
Oct 05, 2013 | Office Equipment & Supplies
Rexel shredder
Spray with WD-40 or similar lubricant/release agent and let it soak for a while, the remove anything that's jamming the sensor with tweezers and switch the unit on and keep cycling between auto and reverse for a minute or two until unit gets unjammed. Then to reduce friction and to protect the blades use some oil in the feed opening, especially after using WD-40 Good luck
Oct 01, 2013 | Office Equipment & Supplies
Shredder sounds like dry rubbing when in use.
Good Luck
Andrew
Mar 16, 2009 | Achiever CCS5000 Shredder
197 people viewed this question
k24674
