Question about Music
Cause and effects of teenage pregnancy at high school
Dunlop crybaby 105q wah effect not working
Sounds like a short in the effects board of the unit causing it to bypass the volume pot.
Feb 19, 2013 | Music
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
Patchmate 8 is suddenly losing half it's level, is it fried?
Without knowing your complete setup it is hard to know the source of the problem... HOWEVER... One problem I see is that if you are using certain types of external effects, this device does NOT use balanced lines (TRS cables) and some of the effects units do use balanced. That, depending on your cables can cost 6DB of gain... and MAY be intermitent depending on whether your cables contact the ring of the TRS connector in the effects unit. This is not normally a problem if you are only using pedal type effects units. Most rack mounted effects are another story. If you need to go between balanaced and unbalanced you may need to use DI boxes. Since this device uses relays, if a relay isn't conducting fully it would distort the sound terribly passing mostly high frequencies.
Sep 09, 2011 | Rocktron Patchmate Loop 8 Floor Switcher
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Gemini FX 7000 DSP effects no longer working, aparently a blown i.c, but which one?
A lot of the effects chips run off of the +5 volt or +3.3 volt power source while a lot of the audio is off +/-12 or 15 volts. Sometimes loss of the +5 causes loss of the effects. Check that before assuming a chip is gone.
Jul 21, 2011 | Gemini Sound Products Gemini FX7000 10...
No functions on the front panel..the display does not change....all voltages to boards present and correct....any ideas?..it belongs to a school....i am a service engineer...but cannot solve the...
This is a wild guess, but I have had a different model, a 110, that had a bad electrolytic power filter cap on the effects board that while a meter showed 5 volts for the effects, what was happening is there was dips in the unregulated voltage that fell below what the regulator needed and the voltage to the DSP fell to the point that the DSP was resetting at twice line frequency. This was ONLY visible using an oscilloscope. ALWAYS verify your power supplies with an oscilloscope to look for ripple and noise. With the processor continually reset, the unit appeared to be inoperative.
Jul 05, 2011 | Behringer V Tone GMX212 2X60 Watt Stereo...
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
Hi ihve soundcraft efx12 & the problem is in the effect, it hanges if i use the program selector, all the leds related to lexicon effects lit up.ithink the problem is in the the lexicon card. please...
If the LED's are level indicators, you are probably saturating the input of the effect and may cause it to hang. Effects use delay and feedback and can cause numerical overflow and the system to basically crash. I would first call the Lexicon support and ask them about this problem... I did have to return one Lexicon product myself for service under warranty.
Mar 25, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Constant hum/buzz only when the distortion is turned up. Otherwise works fine. Already checked cables. Please help.
Distortion is a very HIGH gain operation and any hum on the input will be amplified many times.
Check your guitar AND input cable for ANY hum at all at high gain settings on the amp WITHOUT the pedal in line to assure that the source is not before the pedal.
ADDITIONAL cause could be a poor power adapter for the pedal or even a bad filter cap in the pedal.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
15 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
