Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Change timing belt castle garden solo 570 - Craftsman 42 in. Deck 19.5hp Lawn Tractor
2002 castle garden 13.5 hydro ride on.will not move forward or back , belt ok but not turning on box.any suggestions???
Make sure the main clutch is engaged. It is usually released when you want to move it by hand.
May 10, 2016 | Garden
Castle garden lride on lawn mower engine cuts out when I turn on blade
if your saying engine dies when you engage blade need to adjust the carb rpm
Sep 20, 2014 | Garden
How to time new holland 570 baler
Type in ( manual new holland 570 baler) in Goggle. I used boone, just had to see how time it.
Jun 04, 2012 | Garden
How many miles before i change the timing belt,and head gasket on a city rover 2006 model solo
There is no set mileage to change a head gasket. You only replace the gasket if you have a problem with it. Change the timing belt as outlined in your owners manual. If you do not have an owner's manual, then call your local Land Rover dealer for the correct mileage to change the belt.
May 05, 2011 | Land Rover Defender Cars & Trucks
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Oct 08, 2010 | Prince Castle 740T2 2Channel Single...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
26 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
