Question about D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
3 Suggested Answers
  • 44 Answers
SOURCE: DWL-2700AP reset default settings
Posted on Jul 19, 2009
SOURCE: How to probe the configuration or reset the 2700AP?
thanks for all the supprot...i tried your sugestion and did the same...i could now borwse internet but i cannot access the D-Link configuration website using 192.168.0.50...nothing is coming
Posted on May 07, 2013
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
I am trying to take the passenger door panel off of my 2003 kia spectra however it still seems connected towards the front side of the door but i tryed to removed the two tan screws just free spin i do...
hello,
Disconnect the negative battery cable to prevent shock when handling the door components. Loosen the cable's nut with the pliers and slide it away. Pop off the side-view mirror interior panel with the tweeter on it. Use the door panel trim tool or a flat-bladed tool, such as a putty knife, wrapped in masking tape. Once the panel is off, unplug the speaker connection from behind it. Push the connector's tab in with a flat head screwdriver and pull the connector away. Open the door fully to expose the screw cover on the front part of the door panel. Pry out the screw cover with a flat head screwdriver. Pry out the small centerpiece; not the ring surrounding it. Behind the cover, you'll find a Phillips screw; remove it.
Open the screw cover flap behind the inside door handle. Insert the tip of a flat head screwdriver into the upper-slot; push down to open the flap. Remove the Phillips screw from behind the flap. Pull off the plastic door handle surround piece. Insert the door trim tool behind the panel; pull it back to pull the panel off. Slide the surround piece away from the door panel.
Remove the circular screw cover from the inside door pull storage compartment. Pry it up with the flat head screwdriver. Remove the Phillips screw behind the cover. Remove the screw cover from the rear-edge of the door panel. This cover is similar to the one on the front part of the door panel; pry out the center part, not the ring surrounding it. Remove the Phillips screw behind it.
Remove the two Phillips screws visible along the bottom part of the door panel.
Pry around the perimeter of the door panel with the door trim tool. Pull the tool handle back to pop the door panel clips out. Do this for each side, except for the top. Once the clips are unhooked, the panel is ready for removal.
Gently pull the door panel away from the Optima's door, but only enough to access the area behind it. The connections for the power equipment must be unplugged. Reach around and depress the connection tabs with the tip of the flat head screwdriver; unplug the connection. There are three connections to unplug. Once they are unplugged, pull the door panel away.
Thanks
May 21, 2011 | 2003 Kia Spectra
My door handle from inside of passenger side is broke. How do I get the panel off?
Park the vehicle on level ground and have good lighting available. Open door all the way. Start with a pick, pocket knife or very small slot screw driver. Practically all modern vehicles utilize plastic snaps to secure the perimeter of a door panel. However, you will find that two large screws will hold the door panel on around the "door handle/arm rest" as this is where we pull the door closed....so it needs extra securing. If you look on the bottom portion of the handle, you will see either two access holes pointing up at a 35 degree angle...or two "plugs" which act as "appearance covers" hiding the actual holes. Carefully pop these out. Shine your flash light up the hole and identify the type of fastener. ( it i'll be a large Phillips # 3.....or a torx type fitting) remove these. Now, the other places to look for fasteners you remove from "your side of the door" are at the door handle "lever" remove the cover directly behind this lever. You might find this fastener also has a "beauty cover" remove it and the screw. next, top corner up by the outside mirror. you will have a speaker or a cover there that serves as the cover for the screws that mount the outside mirror. remove the cover. if you see no fasteners or covers, it likely pops off. Just be slow and careful. along with the big screws at the door handle/arm rest, there may be another fastener at the top of the handle. With all of these removed and if you see no fasteners around the bottom of the door...wedge your fingers along the bottom and pull straight out. You will be "unsnapping" the plastic fasteners at the bottom and sides of door. Now you will have a door panel that is loose at the bottom and away from the door frame itself. Barring any trim thats not part of the door panel, you should be able to raise the door panel strait up^^^ and free it from the top of the door. Remember, if its not coming off in a reasonable manner, something is still connected. Once the panel is free, sitting on the edge of the seat, put the door panel in your lap and disconnect the electrical connections, door lever rod...etcetera.....
Write me back and let me know how you did
Theroadisalover
Dec 31, 2010 | 2009 BMW X5
How do i remove the case cover to install a pci host adapter (firewire port)?
I am not sure of the specific case you own and there are a multitude of ways to remove the covers. Look in the back of the tower and locate screws or hex bolts along the outer perimeter of the case. Remove those and pull the cse off. If this does not fit your particular case, you may have a case which only allows you to remove one side of the case, but it will gain you access to PCI slots inside.
May 15, 2010 | Gateway GT5670 Desktop PC
I need info on removing rear door panel on 2004 Grand Prix
there are Hidden Screws you have to Look Hard for Small Covers to them and Mostly there are SNAPS along the BOTTOM and SIDES Screws are Around the HANDLE and Latch
Dec 26, 2009 | 2004 Pontiac Grand Prix
Jul 18, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Reset DWL 2700AP to factory defaults
Hi dear try to flow this tips it will help you
Administrator Settings
Administrator settings allow you to customize User Name and Passwords as an Administrator of DWL-2700AP. The default value of the Username is "admin" with no password entered.
Password
Enter a password in the Access Point Password field. Type the password again in the next field to confirm it. The Password is case-sensitive ("A" is a different character than "a",) and must be between 0 and 12 characters in length
System Settings
You may reset the DWL-2700AP back to factory settings by clicking on Restore Default settings.
Restore Default Settings
Choose Yes and click Apply to restore all Access Point settings to the factory default settings.
Thank you
Imran
Pls rank as possible
Apr 20, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Dwl-2700ap problems
hello!
-- try to change channel and enable security on your wireless network
-- remove other wireless devices on the network because that may cause wireless intermittent in your network
Apr 30, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point Logo
41 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
