Question about Staples SPLXC200D Shredder
Won't stay on
Shredder turns on but turns off within 5 seconds or less. Just purchased on 4/9/14. Last used 4/14/14 with no problems. Very annoying!!
At first the shredder would only run for 3-4 seconds, then quit. Turning the rocker switch off, then back on, would cause the shredder to run another 3-4 seconds, OR pulling the collection bin out, then...
could be the sensor needs cleaning or is now defective. Use a q-tip and insert it where the paper goes. Look for a small button which senses the paper and triggers the stredder motor.
Mar 26, 2012 | Fellowes DM15C Shredder
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
I purchased Shredder Model BD-S600 on 5/6/11. This was to replace another Black & Decker Shredder that I had for only a few months also. Today, when i attempted to turn shredder on to shred some...
If it's like my BD-S600 your motor is already burned out!! Same thing happened to me with this shredder after 3 months of minimal home use. I had to call them and pay $13 to send shredder back to them to have a new one sent to me, and I have already been on the phone with customer service due to problems with the new one after 5 minutes of use! Good luck to you; I know I will NEVER purchase a Black and Decker shredder again! My last shredder (a Brother) lasted 8 years with no problems and I really miss it!!
Jul 05, 2011 | Black & Decker Vacuums
I purchased a 550 series mower last year. It worked great. I used it a week ago and it worked great. Took it out today and it starts right up but won't run for morethan 5 seconds....starts right up...
Hi, remove the bowl off the bottom of the carby and clean it out. My best guess at this stage is that you have water in the bowl. Hope this helps, regards Phil.
May 25, 2011 | Poulan Push Mower
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Key for my Suzuki Aerio 2003
Don't buy it from the dealer, just buy a used remote from eBay. Use these instructions to program it.
1. Confirm that all doors are closed and the ignition key is out of the ignition cylinder.
2. Open the driver's door.
3. Within 10 seconds, Insert key into ignition turn to ON position and back to OFF and remove the key.
4. Within 20 seconds, close and open the drivers door 3 times. (Drivers door should be open)
5. Within 10 seconds, insert key into ignition turn to ON position and back to OFF and remove the key.
6. Press and hold both the LOCK and UNLOCK buttons together on the same remote for at least 5 seconds, the doors will lock and unlock (that's a very good sign)
7. Within 5 seconds, press the LOCK button on the same remote and release. You just programmed your remote ??
Apr 22, 2009 | 2003 Suzuki Aerio
Power won't stay on
plz get the printer checked with professional
Sep 11, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
DM15C stops after 4 seconds, open bin light comes on
I lived with the problem for 6+ Months -- drove me NUTS -- Today, I called Fellows -- Spoke to "JoAnn"... She said this works 80% of the time...
Pull out the bin -- put your foot inside to hold the shredder down -- pull up on the top of the shredder -- you WILL hear a POP as the plastic top disengages from the bottom but TRUST ME THIS IS OK! -- take off this top section (which houses the blades) -- flip it over -- you will see 6 screws total but it is the sets of 2 screws close together to focus on -- right next to the screws you will see a tiny glass sensor -- use a q-tip and alcohol to give them a wipe -- press the top back on -- bin back in -- you are DONE -- This took me less than 1 minute and it works as it did the day I got it! Go shred something!  :)
Feb 09, 2008 | Fellowes DM15C Shredder
Staples SPLXC200D Shredder Logo
47 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
