Question about Microlife Health & Beauty
Service center in singapore
Where can I buy probe covers for my microlife thermometer
How is the electricity distributed in Singapore?
In Singapore, the one who is in charge to distribute the electricity through nation is Singapore Power Services (SP Services). The company provides electricity andgastransmission, distribution services, and market support services to more than a million customers in Singapore. It is one of the largest corporations in Singapore. Singapore Power was first incorporated as a commercial entity in October 1995 as Singapore Power and Gas, but because the abbreviation of that name (SPG) had negative connotations, it was quickly changed to Singapore Power, it was created to take over the electricity and gas businesses of the state provider, thePublic Utilities Board. Since 1995,Temasek Holdingscontrols the entire company with a 100% stake. https://iswitch.com.sg/how-to-iswitch
Apr 17, 2017 | Electrical Supplies
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
Accidentally using US 120V electrical appliance in Singapore without using an electrical converter
If you are in Singapore you may be advised to buy a cheep for the time being and wen you get back home take it in to get it fixed with your waranty.
Jan 27, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
I missplaced my manual and don't remember how to set it. What numbers should I be looking for so I will know if my blood pressure is normal or high
Their site list a manual for the 3AC1-PC here. If this is not compatible with yours, contact MicroLife directly:
Toll Free: 1-800-568-4147 for blood pressure and thermometer support.
Toll Free: 1-888-934-1839 for peak flow meter.
Email: custserv@microlifeusa.com
You can reach customer service 8am - 8pm, Monday - Friday, (Eastern Standard Time)
I hope this helps!
Feb 05, 2013 | Microlife 3AC1 AP Premium Blood Pressure...
I have Sony bdp S580 bought from USA where voltage is 120. I got it to Singapore where voltage is 220. When connected to power in Singapore white smoke came out. I disconnected immediately. What could be...
Contact the authorised service center for Sony at your town. The main power regulator board might have turned irreparable. It has to be replaced as card basis. Only service center can provide its original one. It can't be bought from open electronic spare part market.
May 27, 2012 | Sony Televison & Video
I have a Thermoscan HM1 and am getting error code 2. I need to know what it is and how to fix it. Thanks.
2 says patient temperature out of range. the error codes are in the case. Usually where the probe covers are stored. take them out to look at the codes.
Jan 15, 2011 | Braun Thermoscan Thermometer Probe Covers
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    Unit turns on but no lamp
    Sent to V3 SYSTEMS & SERVICES PTE LTD 64522679,
    they are Projector Service Center in Singapore,
    Nov 25, 2008 | Sony Office Equipment & Supplies
    Health & Beauty Logo
    Top Microlife Health & Beauty Experts
    Colin Stickland
    Colin Stickland
    Steve
    Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
